JDM/EDM headlight adjustable switch/unit - USDM GD Fit
European FitFreakers-
Since I have all, if not, most of the necessary parts and wiring diagram for headlight adjustable unit (it would be located next to the power-folding mirror switch inside my car – same location for JDM coin tray, in case you may be wondering) as seen in JDM/EDM model, a set of adjustable headlights is required to complete the installation. My question is - could USDM headlights be fitted with adjustable unit? If not, is it possible for the imported (JDM/EDM) adjustable headlights to fit (no puns intended) with USDM front end, perhaps, with the use of spacer (for lack of a better term) or related fitment? Your advice/input would be greatly appreciated. Damien |
This is quite a difficult problem. I think that there is no way to fit the JDM/EDM lights with the USDM front. You could measure the housings' length etc. but I guess they are quite different in size.
