DIY - Mugen Short Shift Install
Old Mar 8, 2011 | 09:09 PM
  #61
ivanh's Avatar
hey guys, you know that thing where u have to turn it a quarter of a turn to get it off the shifter? any of yous had trouble getting that off? i have trouble turning the damn thing
edit: nvm, just re-read thread. anyone got any tips into doing this step? thanks
Old Mar 18, 2012 | 11:44 PM
  #62
kodok3ribu's Avatar
Great write up! I've just replaced mine with Mugen quick shifter based on your write up. It's way clearer than the Japanese manual... +rep for you.
Old Jul 21, 2012 | 08:20 PM
  #63
FightingChance's Avatar
How'd you guys get the pivot bushing off? I'm having trouble with it.
Old Jul 21, 2012 | 09:49 PM
  #64
Used pliers and some cussing. Worked.
Old Aug 5, 2012 | 06:58 PM
  #65
jesswin30's Avatar
Curious if this is smoother than the stock shift?
Old Jun 14, 2013 | 06:31 PM
  #66
JdmMac's Avatar
Just used this to do my buddy club short shifter. Great write up, thanks!
The only part I had trouble with was getting the black shift linkage to do the quarter turn. I used some channel locks and used those to turn it and it popped right out.
Btw, this buddy club shifter feels absolutely amazing. I highly recommend it. It feels just like my old STI lol
Old Aug 24, 2018 | 01:17 PM
  #67
daiheadjai's Avatar
Thank God for these instructions.
The pics are down, but this same DIY can be found on Mugen Short Shift Install | Honda Fit DIY
This was super helpful for installing my Buddy Club.
A couple things I'd like to add (maybe it will help):
1) The 2 Centre Console clips (step 2?) are easy to reinstall, but first you have to get that centre "circle" (where you pushed in to release the clips) to "pop" back out. You have to fiddle with the clips but once the circle part is fully popped out (not flush with the rest of the clip, but rather poking out), you can insert it into the hole and then push that raised centre part back in (flush) to lock the clip in place.
2) The metal retainer for the right-side linkage was pretty tough to pull out for me - I had to use pliers to wiggle it out until I could fit a flat screwdriver between the bottom of the clip and the linkage and pry it out. Once you get the screwdriver worked in there, it's easy to pop out.
3) The black linkage on the left seemed easier to pull out once you release the cotter pin and washer to remove the linkage and get it to hang freely. As JdmMac pointed out, channel lock pliers made it super easy to pop back out
4) The torque specs for the 4 bolts to secure the shifter box are 16 lbf-ft or 2.2 kgf-m, but I just tightened them as much as I could using my ratchet.
fritz269
Aug 11, 2016 08:14 AM
SilverEX15
May 22, 2015 09:57 PM
donaidh
May 15, 2013 03:58 AM
sh00k
Apr 30, 2012 08:21 PM
jazzman
Dec 28, 2008 11:44 AM
