Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   Fit DIY: Repair & Maintenance (https://www.fitfreak.net/forums/fit-diy-repair-maintenance/)
-   -   Searched can't find oil drain plug torque specs (https://www.fitfreak.net/forums/fit-diy-repair-maintenance/18437-searched-cant-find-oil-drain-plug-torque-specs.html)
moates Nov 11, 2007 05:47 PM
Need torque specs for oil drain plug mostly, but are there any good write ups with all Fit info?
AppleMac*Fit Nov 11, 2007 06:18 PM
https://www.fitfreak.net/forums/fit-...6k-beware.html
manxman Nov 11, 2007 06:46 PM
It'll take you awhile to find what your looking for in the above thread. Just replace the copper crush washer, and tighten the plug snugly. If you must have a spec.- use a torque wrench set to 20 lb.ft. but don't forget the new washer! Better yet, buy the Fumoto drain valve to replace the plug and washer altogether, and you will never have to R&R the plug again.
moates Nov 11, 2007 06:56 PM
got it, it's in the manual. 29ft lbs.
© 2026 MH Sub I, LLC dba Internet Brands
