AT transmisison change interval, parts?
Okay, so I'm at 10,000 miles now... since I also drive a VW, I get paranoid about maintenance (if you don't do maintenance "on time" or earlier, then you will end up with a very expensive bill).
Went through my first oil change at 6,000 miles at 20% "oil life", and UOA was fine. Switched to Mo1 5w20, will get another UOA at 12k. On to the questions!
How come you know so much about turbo sizing but you don't even know how to check the ATF level in a FIT? :confused: Kind of backwards most people know the basic stuff before moving onto advanced turbo selection. :rolleyes:
Originally Posted by claymore
(Post 275666)
Neither that nor this is adding anything useful to the thread. Try to be more helpful... My family member suggested just driving to one of those places that do it for you by tapping into the lines (flush?) For my old a/t Jetta, the forums discovered around 30-35k helped avoid issues (manual stated a much longer period). I'll probably do something around 60-70k with the Fit's a/t fluid (like, 1.5-2 years more...) |
It's a legitmate question for the OP. :p But thank you O'so much for your concern about what I post ;) but you didn't offer him any advice germaine to the FIT auto transmission in your post either.:rolleyes:
(Post 275666)
Well for one, I'm an engineer, I've owned two fits, the first one was quite possibly the first fit accident in the USA. I got my second fit in November, and I haven't received my service manual yet. As for turbo sizing, does this really have anything to do with this thread? No. Tell you the truth, I don't even know where to tap into the oil supply for this engine. Sounds like a bunch of homebrew turbo people on that part of the forum don't know much more than I do. Why don't you go harass them? Maybe I was also trying to encourage discussion on this subject since one transmission is different than another. I don't make assumptions on a hydraulic system, ever. some you measure running, some you don't, some have a dipstick tube that needs to be at a precise temperature to be able to check. Did you know there is a VW transmission that you can't change the screen without removing the transmission and ripping it apart? it's called an 09A. Maybe this transmission has a similar setup. Sometimes there is a different fluid with the same characteristics of the OEM fluid that is 1/10th the cost. I'm not a moron, I just don't make assumptions, and I ask questions, lots of them, because there are other people on this board with something to add to the conversation. Congrats on pissing me off... |
(Post 275687)
actually he gave more advice than you did claymore... Why don't to you go read a Dale Carnegie book and change your life? |
Originally Posted by xorbe
(Post 275667)
(Post 275667)
(Post 275667)
It's still a legitimate question. You did such a nice job on the turbo stuff and that was a complement so it's a conundrum as to why you didn't know the simple stuff nothing to get all bent about. It's unusual that's all nothing implied I simply wondered how you gained all that knowledge about turbo charging which is an esoteric subject to many members but professed a lack of knowledge to something as simple as checking the fluid level that is unusual that's all nothing derogatory intended.
(Post 275780)
A hydraulic system is something each engineer would do uniquely. Something along the lines of Monet (not Monet) versus a Van Gogh. Different approaches to make the same solution. Since I'm not familiar with Honda's transmissions (Actually they are probably made by AISN) I didn't assume I knew how to check the fluid level properly. That being said, I'll counter the question with something. How would you go about checking the AT level on a 1999 VW Jetta? Unless you had been around a VW forum and asked the question, or owned the service manual, it would be impossible for you to do a pan drop without a VAG-COM or a IR Temperature scanner. You could get into trouble if you asked questions after the pan is down. Also, VW specific ATF fluid is required, and the interval should be no longer than 40,000 miles (A.K.A the lifetime of the crappy transmission). Assuming you know how to do things is what puts more VW's in the salvage lot. I know Honda makes a better system, but it's probably better to ask now, then find out later that I screwed something up. Sure you could make the assumption the amount of fluid you removed should be the amount you put back in, but how can you make sure the previous person didn't screw something up? Sorry if I took it the wrong way, but it was as if you were trying to start something. |
No just interested you showed a high level of learning about a complex subject that has some members scratching their heads. And most car enthusiasts start at the bottom of the learning curve by starting with the small stuff and work their way up to the complex subjects not the other way around.
And I have a manual Transmission so I couldn't tell you how to check the level in your automatic because I have never read that part in my owners manual or the repair manual either |
(Post 275798)
I'm not a beginner on cars in general, and I wouldn't dare make a different turbo kit on a car I know next to nothing about, however selecting a turbo size based on the displacement of the engine is an elementary calculation. |
I work in warranty maintenance so i can give my/a generic answer.
I would do the first service at 30k, especially the way you drive. It might say 60k in the book, but that's my suggestion. You can use a honda spec fluid or another one(Mobil makes a fluid that meets many manuf. specs)...my experience with Honda's has been that most of them dont require a Manufacturer only fluid. Normally i would recommend taking it to a lube shop and just let them do the flush...but you seem opposed to that. What is the reasoning behind your mindset? Have you had a bad experience or is there another reason? I have a MT so i just assume there is a dipstick for the tranny on AT, but i have no experiences with AT. Just my 2 bits, SSFit |
Mostly the reason behind the flush being a bad idea (power flush, not one that uses the flow of the transmisison to change) is it usually will drum up some of the particulates in the pan and suspend them in the fluid, wearing parts that are touched with the fluid.
I've mainly heard of horror stories with people that have had problems after flushing. It could have just been a coincidence. |
Yeah, my Jetta is a 1999. Everything about that vehicle is unreliable, lol. The tranny was replaced at 95k miles, reverse quit. I'm an engineer too, though in CPU design, started out mechanical. I say, figure out the Fit in any order you want. If you do flush the a/t, post some results too.
Originally Posted by alphaseinor
(Post 275621)
I dont know much about the power flush, but the one i do at my shop uses the flow of the tranny to do the work...havent seen any negative results yet. +1 to leonine's post
Wow just 25-30k? That's like 18 months for me... I'm already past that, how much does a normal "a/t fluid flow swap" cost anyways down at the transmission shop?
I'll change it in another 5-10,000 miles... Shouldn't be too hard.
User's manual calls for very long. ATF is something not changed as frequent. Honda stock Z1 ATF for stock transmission only. Honda has certain friction modifiers in its ATF.
Although i've used Amsoil (the only one advertised as z1-compatible in my auto) i dont recommend it on a stock transmission or until you're boosted. |
Originally Posted by 03DSM-RSX
(Post 277691)
Sounds like you're certain I'm boosting this car... lol... not like I'm studying that at the same time... |
