Amsoil Engine flush
Anyone flushed their engines with this? My car has 170k miles with oil changes done everytime the maintenance minder told me. I started using fully synthetic oil at around 100k miles. Now I'm wondering if flushing my engine with the Amsoil engine flush will do me good or do I just continue with my regular oil changes?
....:popc:.....
Originally Posted by spreadhead
(Post 863385)
....:popc:.....
........:popc:....... nope |
I think that Honda actually states that you shouldn't use engine flush products in the manual. I cannot remember if it was my S2000 manual or my Fit manual I read that in though...
Pull the cam cover and look before you decide you need to do anything. AutoRX is best if you think you need an internal engine cleaner.
doesnt higher rated gasoline kinda do the same thing? I would just move from a 87 to a 90 or 91 gas for a awhile. other than that, hondas' are pretty tough to beat. i would take a minute and check out the fuel injectors though. Now thats pricey!
Its good stuff, rather then being solvent based, its
detergent based engine flush. Check out the reviews over at Bob the oil guy. |
Originally Posted by ramjet
(Post 878898)
Originally Posted by Oofie
(Post 863372)
I think you've said it - it might 'do you some good', but your engine certainly has no need for a flushing. By following all scheduled fluid changes you have effectively done the same thing. Never a good idea to do something just to do it - if it ain't broke don't fix it. |
