DIY: GD Clutch Hardline
Old May 22, 2011 | 04:20 PM
apexanimal's Avatar
^ nice!!
glad this was helpful for you...
Old Jun 21, 2011 | 02:06 PM
joey_fits's Avatar
Sorry to bring back an old thread ; is everything still good without delay valve? Thanks for any input
Old Jun 21, 2011 | 02:58 PM
apexanimal's Avatar
still good!
Old Jun 21, 2011 | 03:37 PM
joey_fits's Avatar
Originally Posted by apexanimal
still good!
Soooo happy to hear. Goodbye cdv thanks apexanimal!!
Old Jun 21, 2011 | 06:18 PM
airwicc's Avatar
I need to do this this summer. Although I've been driving my Fit for a year now.. I still find the Fit's clutch engagement is not to my liking. Gotta make everything feel solid and to my liking.
Hey Apexanimal I gotta question on the "Clutch Pedal and Clutch Pedal Adjusting Bolt Adjustment".
If you adjusted the pedal of the clutch wouldn't the clutch be riding until it wears out? A little confused about the diagram you posted.
Old Jun 22, 2011 | 10:13 AM
apexanimal's Avatar
the clutch pedal adjustment is designed just to take out unnecessary play at the BOTTOM of the pedal travel... the entire pedal gets adjusted down, so it doesn't affect the engagement and holding travel at all...
the trick is to adjust it down, start the car, and see how much play you have at the very bottom of travel to where the clutch just starts to grab... if it's too much, adjust it down, etc...
Old Jun 23, 2011 | 06:32 PM
thejroisgo's Avatar
The parts to do this arrived today, I'm stoked to get everything installed. Thanks for the write up!
Old Jun 23, 2011 | 10:19 PM
apexanimal's Avatar
no worries - hope it goes well for you
Old Jun 29, 2011 | 12:23 PM
Carbuff2's Avatar
Props to you ApexAnimal! Nice writeup.
Old Jul 28, 2011 | 10:34 AM
Willard's Avatar
Could someone look over my purchase list and see if it looks ok?
I hope to just replace the CDV and the rubber line. The new system will hook to the clutch master cylinder and to the hard line at the bracket on the tranny.
Thanks!
There are several different lengths avaliable (would need to measure it off to make sure it is long enough) (24" = $15.95)
http://www.summitracing.com/search/Brand/Aeroquip/Product-Line/Aeroquip-Teflon-Racing-Hose-Hydraulic-Brake-and-Clutch-Couplings/Hose-Size/minus-3-AN/Hose-End-2-Angle/90-degree/?Ns=Rank%7cAsc&autoview=SKU
(straight end for the connection at the bracket and a 90 degree end at the master)
(For the connection to the hard line on top of the tranny vs. running the whole way up to the salve cylinder)
http://www.summitracing.com/parts/RUS-R41411/ ($17.06)
Female 10mm x 1.0, Male -3 AN, Steel, Chrome, Each (Designed to fit Japanese style inverted flare)
(For the connection to the master cylinder)
http://www.anplumbing.com/search/index?search_text=305-03M121 (click the goodridge tab)
12 MM X 1.0 male bubble flare to -3 male steel (305-03M121) $14.99
Old Aug 1, 2011 | 10:41 PM
apexanimal's Avatar
^ looks good...
double check the length you need, and double check the adapter you need for the tranny connection... i didn't do that one so just be sure...
do a write up on here once you're done...
Old Oct 28, 2011 | 02:04 PM
  #32
KeithDigital's Avatar
Are there any shops that sell this as a kit yet?
Willard - did you finish your setup?
Old Oct 31, 2011 | 08:19 AM
  #33
Willard's Avatar
Not yet... I am still sitting on my thumb.
I flushed the fluid and the 1st gear clutch release shudder/studder (from a stand still) is still there. My worry is that even with the new line in place the issue won't go away.
Has anybody removed the CDV and had the clutch engagement improve?
Old Oct 31, 2011 | 09:07 AM
  #34
apexanimal's Avatar
yes... me...
the shudder isn't the issue of the cdv... it's an issue of an overly light pressure plate for the type and friction of the clutch plate...
the cdv has more to do with the timing of the releases and engagement points...
Old Oct 31, 2011 | 09:53 AM
  #35
Willard's Avatar
Fudge... I had hoped that removing the CDV would help with the shudder/studder.
Oh well... time to add a clutch-PP R&R to the 'to-do' list.
Old Oct 31, 2011 | 03:23 PM
  #36
apexanimal's Avatar
removing the cdv WILL help you modulate the clutch better so by using some skill you can avoid it...
Old Dec 19, 2011 | 08:17 AM
  #37
Willard's Avatar
2 of the 3 pieces arrived this past week.
I hope to install it over the holiday and will have a DIY/photos/parts list.
IIRC it was ~$67 total (shipped).
Old Dec 19, 2011 | 10:12 AM
  #38
apexanimal's Avatar
:thumbsup:
Old Jan 13, 2012 | 11:36 AM
  #39
GAFIT's Avatar
Sorry to bring back an old thread, but the info here is GREAT! I'm going to tackle this soon because I can't stand the delay and numb feeling of the clutch.
Old Jan 13, 2012 | 10:02 PM
  #40
apexanimal's Avatar
thank you sir...
i also HIGHLY recommend the following:
adjust the clutch pedal down (takes out a lot of unnecessary play at the bottom)
fill/stiffen the front trans mount
good luck/post pics
