AMSOil oil change for extended intervals!
Old Aug 10, 2011 | 08:14 PM
lcq4blackstar's Avatar
- 4q
Signature Series 5W-20 Synthetic Motor Oil
- 1 AMSOil Absolute Efficiency Oil Filter
So I'm not going to tell you how to change your oil as there are plenty of those on this forum. I'm just going to say why I decided to run this oil/filter combo. Basically I have been running the Torco oil and Honda filter recommended by Kraftwerks with a 3,000 mile interval since the install of the base kit. The shop I pick up the parts had AMSOil 5w-20 XL Extended Life Synthetic motor oil, so I picked 4 quarts of that up with a Honda oil filter. I ran this for two maintenance intervals (6k), unfortunately I don't think the Honda filter should be pushed that far. Since going with AMSOil in this car I have decided to exclusively run it along with all their other products.
I've gone with the signature series as its good for up to 25,000 mile intervals (I'll be changing it out with the filter @ 15k). I've also decided to go with their Oil filter as well as it is good for 15,000 miles. This is the equivalent of 4 regular oil changes!
So for $56.50 - divided by 4 changes = $14.12 equivalent!
I've ran AMSOil oil in my transmission and motor of my last turbo car with great results in the past, so I've got great confidence in this setup for our cars.
Don't forget to mark your next millage change interval somewhere and a new drain plug crush washer!
Old Aug 10, 2011 | 08:48 PM
Krimson_Cardnal's Avatar
Yup, it will work. I'm changing my good old dino at 9K. As long as you're happy, life is good. Can't say my L15 is happy... it's inanimate, but it runs fine.
Old Aug 11, 2011 | 05:54 PM
DOHCtor's Avatar
This is what my valvetrain looks like after 140k km of abuse with AMSoil and Red Line oils in it since the beginning...
...i think it's clean!
Marko!!
Old Sep 3, 2011 | 06:25 PM
Buzzbomb's Avatar
I've got a thread on here with some oil analysis' on my Fit using AMSOIL.
I just changed the oil today. It has been one year and a month. 17,xxx miles on the oil.
In that time I added maybe 3/4 of a quart of oil total.
My Fit had just over 60K miles on it and has had 4 oil changes.
JDMxGE8
124
Feb 15, 2015 10:14 AM
SmartSizer
Mar 12, 2008 02:15 PM
ludexr
Sep 17, 2006 10:13 AM
Paulo107
May 31, 2006 09:04 PM
coldstorage5
May 4, 2006 07:21 AM
