Slow Tire Leak
Old 04-17-2013, 08:55 PM
Carbuff2's Avatar
I routinely plug nail-holes in my fleet's tires. Never had a problem. (Well, I DID have to re-repair one plug after it had been installed for 25,000 miles...)
For less than one repair at a store, you can buy a kit.
Slime 1034-A T-Handle Tire Plug Kit : Amazon.com : Automotive
Then, all it takes is a spray bottle with soapy water so you can find the leak. (The leak will blow bubbles.) Yes, don't forget to spray the valve, I've had a few of those leak.
I've had problems with the supposedly superior remove-the-tire-and-patch procedure. Either the patch leaks or the tire needs re-balancing...
The cheekiest thing I've done was one time when I got a drywall screw in the sidewall of a nearly new tire. Most tire shops will NOT repair this type of damage in a sidewall, so I unscrewed the drywall screw a ways, covered the threads with black RTV (<---style points?) and screwed it back in. Lasted another 20,000 miles and two years until the tread wore out!
Old 04-17-2013, 10:07 PM
ohw
ohw is offline
1. There is a minimum size for the hole in the tire to use the tire plugs. If the leak is from a very small hole, I won't make the hole bigger just to use the plug.
2. Patch from the inside is better than plug, even both methods work.
3. Walmart usually does not have the experience like tire shop pro's working there. Similar to the can tire fix stuff, I would use it for emergency only.
Old 04-22-2013, 07:33 PM
GTRPLYR's Avatar
So I took the car in to my Honda Dealership today and turns out it was a nail. Not sure if they patched or plugged. After waiting 3 hours I just paid the $25 charge and got out of there.
Despite the unusually long wait time for the work I'm glad it was taken care of and repaired.
Old 04-22-2013, 08:23 PM
2012FitFan's Avatar
Glad you're all fixed up buddy!
Old 04-22-2013, 09:52 PM
GTRPLYR's Avatar
Thanks 2012FitFan!
In hindsight I feel rather stupid I was driving around with a nail in the tire but it was very apparent when I tried to look for it and thought it might be the valve or some other tiny little leak.
Old 04-22-2013, 10:21 PM
Subie's Avatar
Top drawer, 2nd slot, in your "Lessons Learned and Best Practices" tool box is where this one goes.
Old 04-23-2013, 12:21 AM
xxryu139xx's Avatar
damn 3 hours for a nail! u should have went to a local tire store and had them check out the tire first. it took me less than 15 minutes from walking inside the shop and paying 15 bucks to get it done.
Old 04-23-2013, 01:42 PM
GTRPLYR's Avatar
Exactly.
Being in SF everything is a bit of a hassle with parking and such. The dealership was close and easy for me. But even with grabbing lunch I thought the time was excessive and was a bit pissed. But with dropping it off and doing the paperwork I was pretty much committed to having them do the work.
Old 04-23-2013, 05:16 PM
if it's a nail i plug it using that plug carbuff posted. it works fine given that you do it correctly. if it's a big hole i have a tireshop plug it from the inside, or just get a new tire.
i bet A LOT of folks right now are drving around with nails and crap stuck to their tires without knowing.
instead of doing these dumbarse meaningless OBD2 scan smogchecks on modern cars, they should be checking tire pressure and conditions of tires.
Old 04-23-2013, 05:25 PM
Subie's Avatar
So you expect people to know they're running flat without TPMS? Find directions without GPS? Or drive with cell phone off? Sorry... Off my soap box...
Frylock017
08-04-2018 08:03 AM
all4one
07-10-2009 01:06 PM
sterVin
08-30-2007 08:50 AM
Rob B
05-04-2005 04:44 PM
Quick Reply: Slow Tire Leak
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
