driver side transmission mount torn
Deleted....
The mount only costs $29 - $42 USD at Rock Auto. Appears to be easy to replace once the drivetrain is supported.
More Information for ANCHOR 9250 :thumbups: |
Il recently installed that exact mount. I've read only really bad reviews online that the anchor mounts fail very quickly. I just installed it this month so I hope I'm still good. Just know that the mount is cheap but it doesn't have a good reputation.
Originally Posted by MTLian
(Post 1260551)
Would shoving a white eraser between the gills of the mount give your stiffness as well as back to school savings from Staples? The answer is yes I did so and it was very stiff until they ground to a pulp. But they didnt hurt the rubber in the mount because it is softer yet stiff enough. Cheep fun for a day of hard driving. In my GFs Cobalt I could fit a whole 10mm deep socket passing right through on the lower motor mount. That is some gap these days .
that mount is nothing more than a positive stop mount...
it really only serves to stop the motor/trans movement at its limit... with that said, the first stop to firming up my motor mounts was to fill that one with a crap load of windowweld... and it did help quite a bit... |
Originally Posted by apexanimal
(Post 1260672)
(Post 1260672)
it really only serves to stop the motor/trans movement at its limit... Mine tore, I was gonna replace it but the rusted bolts broke off in the frame. So, I've driven several thousand miles without it. I'm not dead and the car still runs, so I guess it's fine. |
Originally Posted by Jack stands
(Post 1260721)
^This.
