Ciggerette lighter outlet doesn't work
Old Sep 26, 2014 | 01:33 AM
F-it good's Avatar
Just the other day, I've notice the car outlet doesn't work. tried charging my phone but wasn't getting any power. I checked all the fuses, none were burnt or popped. So I'm guessing that the outlet itself is broken or I could be wrong. Anyone else has this problem and fixed it?
Old Sep 26, 2014 | 01:01 PM
jbolanos's Avatar
Hi, same problem here. I checked the connector below the center console and it is plugged in but no power comes from the outlet.
Old Sep 26, 2014 | 03:52 PM
DWils's Avatar
Did you try using a charger that you had previously used to charge your phone? I ask only because sometime some chargers don't charge my phone, but if it was a charger that you had previously used to charge your phone then that is odd, especially if there are no blown fuses.
Old Sep 26, 2014 | 05:05 PM
Wanderer.'s Avatar
Yeah, first thing is to check the charger. I have a charger that crapped out on me and I thought it was the fuse or socket for sure, but nah.
vinnimac
Jul 2, 2014 05:18 AM
CptanPanic
Feb 2, 2013 05:06 PM
angeldragon0
Mar 4, 2008 04:04 PM
benlinus
Nov 21, 2007 12:36 AM
Balorn
Jul 21, 2006 05:58 PM
