Fit Engine Light/Alarm Question
Hey there,
Been a while since I've posted in the forum, been busy with school and stuff. Recently my engine light when on due to my "check fuel cap" message flashing. It did this on and off for about two weeks until somehow i fixed it and it hasn't flashed the message since. However my engine light is still on after about a week or two of driving since the message dissappeared. I was away in Washington, DC last week and when i got back my alarm system wasn't working and i found out that the sensor that goes to my hood latch was the cause so i unplugged it and the alarm has been fine since. Just curious if there is anyway that the alarm system could effect the engine light? (i don't see how it would) and if not, has anyone else had a similar thing happen with their engine light/fuel cap? |
You are getting a check engine light? No the alarm system would not have anything to do with that. You need to see what code(s) are coming up to cause that check engine light. Once you know the code(s) you can go from there
Originally Posted by MNfit
(Post 1272631)
Basically, I'm just curious if anyone else has gotten engine lights from gas caps more than once and how they dealt with them? |
NO the dealer was WRONG I have been driven 2 miles without gas cap with warm engine an there was no warning light.
Get a basic code reader($50), pull the code and post it here. |
A lot of times you can go down to an atuo parts store and they will be able to pull the codes for you for free. when you get the code check to see what it is. Check Engine Light codes (CEL) Diagnostic Trouble Codes (DTC) Malfunction Indicator Light (MIL) and - Honda-Tech
Turns out a buddy of mine actually has a code reader so i'm going over there thursday night to figure it out. I will post the code up here as well. never had problems with engine lights on my cars before so this is all relatively new to me. :ohnoes:
Thanks for the suggestions and comments MNfit and doctor J. |
My check engine light a couple weeks ago was caused by gas cap. Took it off and put back on snug and was fine. CEL went off. I had this happen a few yrs ago as well.
Originally Posted by Black3sr
(Post 1272979)
stupid gas caps... |
Hey guys,
so i got the code read and the code that came up was "P0455" which is a large leak in the evap system. The gas cap seems to be fine. I'll probably take it in to a shop that my friend has had good experience with and see if they can find whats causing it. |
