Add headlight warning buzzer?
I have a friend with an '09 Fit. It seems she forgets to turn off the headlights regularly and would benefit from a warning buzzer.
I am not familiar with this car, but thought it might be possible to add a warning buzzer as I have read about it being done on other model Hondas. Thanks for any help with this. |
There should be a warning chime if the engine is turned off with the lights on and you open the door? Mine has one. I think. I don't often forget but I seem to remember a few times I did and there was a chime.
Or do you mean some other kind of buzzer that works in a different situation? |
This is not my car, but I suppose I should have asked that question.
I just assumed that since she has the problem of finding a dead battery due to lights being left on, that there was no warning buzzer. If there is, it must not be very effective for her. I have seen on some other Honda forums that a piezo buzzer can be added to the fuse block. I hoped that this had been done to a Fit and instructions might be available. Thanks. |
