Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   Fit DIY: Repair & Maintenance (https://www.fitfreak.net/forums/fit-diy-repair-maintenance/)
-   -   2008 Fit - Driver's side window stuck 3/4 up (https://www.fitfreak.net/forums/fit-diy-repair-maintenance/91962-2008-fit-drivers-side-window-stuck-3-4-up.html)
karma279 Dec 15, 2015 04:13 PM
6 Attachment(s)
I posted this in the First Gen forum... but thought it might do better here:
2008 Fit
The driver's side window got stuck around 3/4 up and won't budge... From the pics you can see it looks like it could be off track and/or stuck/wedged in the rubber stripping... I've tried to pull it up (by myself), no luck... Suggestions?
https://www.fitfreak.net/forums/atta...ine=1450213982
karma279 Dec 15, 2015 05:51 PM
So I popped the door panel off... There's about 6"ish off the rubber tracking (the window is "outside" the stripping/tracking), starting where the door panel top starts - going down...
I was afraid I'd put the glass in a bind and break it trying to get it back in... So I'm just gonna run it down to a local body shop... Mods, feel free to remove this post.
© 2026 MH Sub I, LLC dba Internet Brands
