08 base fit, all windows won't work and rear wiper won't work
Hello all, I just purchased a base 08 fit for cheap.
The windows (all 4 ) won't go up or down. The window fuses are fine and the window lock switch is not depressed. I tried swapping the 40a relay under the hood with an identical relay and they still don't work. I pulled the driver door panel to check to make sure the connectors were connected and they looked fine. That's issue one. Issue 2 is the rear wiper doesn't work. I have a multimeter but I can't really figure out how to test the motor or wiring to check whether it's getting voltage. I'm trying to fix these before I put it through inspection and the shop try's to charge an arm and a leg for the repairs. Can you guys point me in a better direction? I'm pretty mechanically inclined but electrical problems confuse me. Thanks! |
If no one has any idea , is there a good diagram for both fuse boxes showing all the relays and fuses? I mean I can read the panel that you pop off to get to the fuses but it's written in shorthand so I could be missing something.
Fit '08 Rear wiper and all windows don't work
I just did a search to see if I can repair this issue myself. Driving yesterday in rain, my rear wiper stopped midway, and simultaneously all four windows became inoperable. I thought it might be a fuse.
Can anyone offer ideas or advice on this? |
| All times are GMT -4. The time now is 01:01 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
