2015 Fit Hood/Washer Trim Removal
So today one of the two washer nozzles stopped spraying. The passenger side one is working just fine but the driver side one sprays nothing. Thought maybe it was clogged so I tried to unclog with no luck. Thinking there's either a kink or blockage in the hose looping from the first sprayer to the next, or the hose has come off altogether. Before I start tearing up stuff, does anyone know how to safely remove the trim at the windshield washer edge of the hood where the spray nozzles live?
Probably just the nozzles (dirt, or ice)
Spray them with a penetrating oil (Kroil or PB Blaster), let soak for a minute or two. THEN have a helper hold a finger over the working nozzle while you actuate the washers, to force all the pressure through the clogged one.
Clean the penetrating oil off the paint promptly.
It wasn't hard to remove. IIRC, it's 2 bolts, and a bunch of plastic clips. The trim is in 2 pieces.
https://www.hondapartsonline.net/aut...gine-hood-scat
tevas
09-16-2019 04:19 PM
Slick15EX
07-18-2018 03:07 PM
Andrewi56
11-11-2014 07:09 PM
