Air Conditioning Disaster
My 2008 Honda Fit Sport is experiencing issues running the air conditioning, and I'm not sure what steps to take next.
The AC won't run under hot/humid conditions and often will only run when the car has come to a rest. Here's what has been checked, rechecked, and verified. -blower motor relay inspected -entire system checked for leads -new condenser fan relay -new compressor clutch relay -new pressure switch -system completely evacuated -new freon installed with close to optimal pressure levels The AC will run cold for a few minutes, then shuts off. I don't know what to do next in this troubleshooting escapade. AC experts out there: what's your advice? |
Does your condenser fan spin when you turn on your AC?
Besides making sure your auxiliary fan is coming on I would have the shop double check the pressure. These smaller systems seem to be picky about having the exact right amount of refrigerant/pressure.
Just to be certain of what you're saying...has the system been vacuumed down and then refilled with the correct amount of refrigerant and oil by a reputable shop? |
