Q: Radiator fan and temperature
Old Nov 22, 2006 | 10:10 AM
kps's Avatar
kps
Honda Fit Forums Moderator
Does the radiator fan come on at a fixed temperature?
(I've tried searching the site, but "fan" isn't in the index.)
Old Nov 22, 2006 | 10:31 AM
wyy183's Avatar
Yes, and according to my ScanGauge, it is around 200 degrees F. The highest temperature that I've ever seen, in hot weather - stuck in traffic, was 204.
Old Nov 22, 2006 | 11:52 AM
kps's Avatar
kps
Originally Posted by claymore
you can find al kinds of info you might want IF YOU LOOK IN THE MANUAL.
I have the paper manual for my actual model. The fan circuit diagram includes a connection to the ECU and the troubleshooting sequence includes swapping the ECU, so it's not obvious that the fan thermostat is the only determinant.
gerard6496
Jan 12, 2024 02:12 AM
boltaction
Jul 11, 2018 10:52 AM
mangosmoody
Jun 19, 2016 07:38 PM
Thor28
May 22, 2007 11:17 AM
Al Davis
May 15, 2005 07:30 PM
