T1R Turbo Kit
Old Jun 24, 2008 | 11:16 AM
  #121
kelsodeez's Avatar
UNBANABLE
Originally Posted by SWRWKFS
So Has Anyone Learned anything about the CEL and how to get it to turn off? or about this emission passable cat?
Any opinions on what else should maybe be bought with the kit? like a turbo timer or something?
the cel is a non issue. i got that light and talked to ben about it. its the code for the barometric pressure circuit. i was told to ignore the light for now as it doesnt affect performance but ben is working on a fix for the plug.
Old Jun 24, 2008 | 11:24 AM
  #122
YeeFit's Avatar
I would recommend an oil cooler to go with the kit.
Old Jun 24, 2008 | 11:27 AM
  #123
Illusive's Avatar
Turbo timer would be a good idea too, unless you wanna sit in your car for a few minutes after you arrive at your destination...I hear Sumo is pretty good at that haha
Old Jun 24, 2008 | 11:31 AM
  #124
kelsodeez's Avatar
UNBANABLE
the only crappy thing about having a turbo timer is that you cant lock your car until it turns off.
Old Jun 24, 2008 | 11:33 AM
  #125
GD3-Fit's Avatar
I <3 SPOON
walk away and do the car remote under your chin and lock trick
works everytime
Old Jun 24, 2008 | 11:39 AM
  #126
kelsodeez's Avatar
UNBANABLE
works everytime
it doesnt work like that. bluecell knows whats up with that.
Old Jun 24, 2008 | 01:29 PM
  #127
YeeFit's Avatar
If you get a remote starter that has a turbo timer feature, then you can get out, lock the doors with the remote and the car will run for about 2 minutes or so and then automatically shut off and make sure the doors are locked.
I've been on the fence with the T1R kit.. I want it, but the KWSC kit sounds appealing with the 10psi highboost/hondata option.
  #128
BlueCell's Avatar
Recommended things to get, Turbo Timer, Air/Fuel Gauge, Boost Gauge, and some Oil temp/pressure gauges. Oil cooler is not needed unless you are constantly boosting like tracks. I live in Texas and it's hot here. That CEL is barometric pressure reading. I get it on and off. Its just the sensor in the intake manifold thats saying AHHHHH TOO MUCH AIR lol. Otherwise it doesn't affect anything.
Old Jun 24, 2008 | 01:32 PM
  #129
BlueCell's Avatar
Originally Posted by YeeFit
If you get a remote starter that has a turbo timer feature, then you can get out, lock the doors with the remote and the car will run for about 2 minutes or so and then automatically shut off and make sure the doors are unlocked.
You can boost the T1R to 10psi, just need to change the fuel mapping.
I like the stock alarm and don't really wish to get a new one. I'd just want to modify it so it locks when the timer goes off or I can lock it manually when I get out of the car. Anyone have any clues on that?
Old Jun 24, 2008 | 01:36 PM
  #130
kelsodeez's Avatar
UNBANABLE
i am going to try a few things tomorrow with an override on the connection between the locks and the ignition. might make the car less safe from thieves though.
Old Jun 24, 2008 | 01:58 PM
  #131
Previc93's Avatar
I have a question. does vtec still work with the cel on??? i thought that when the check engine comes on that it runs in limp mode which is without vtec... or at least thats what i thought. and if so would it run faster with the cel off??? If someone could inform me that would be great. im debating whether i should get this kit or not.
Old Jun 24, 2008 | 02:26 PM
  #132
kelsodeez's Avatar
UNBANABLE
yea. vtec works. the cel is called a soft warning. its not detrimental to the engine so it doesnt run in "limp mode". i just bought a barometric pressure circuit from an acura rdx so i am going to see if that works. if it does, then problem solved.
Old Jun 24, 2008 | 02:38 PM
  #133
BlueCell's Avatar
Vtec does work. 1st gear for me scratches going in the higher rpms. So it's definately working. (beat a 350z on sat rolling from 40mph)
Old Jun 24, 2008 | 03:51 PM
  #134
YeeFit's Avatar
Its quotes like this that make me wanna change my mind and go T1R over KWSC...
Sounds like both kits have had their fair share of glitches...
Old Jun 24, 2008 | 04:12 PM
  #135
sumo's Avatar
^ DOOOOOOO IT COMEEEEEE ONNNNNNNNN lol
Old Jun 25, 2008 | 12:46 AM
  #136
YeeFit's Avatar
Heh... I would, but I think I am commited to the KWSC highboost kit when it comes out. I want the T1R cause it is available now... but I think if I wait I will be happier.. i hope!
Old Jun 25, 2008 | 12:10 PM
  #137
eldaino's Avatar
no oil cooler blue? are you a/t or m/t?
Old Jun 25, 2008 | 01:36 PM
  #138
BlueCell's Avatar
I have a manual and no oil cooler. Had my kit on since April. No signs of oil leaks yet.
Old Jun 25, 2008 | 01:41 PM
  #139
sumo's Avatar
yea getting oil cooler and new rad would prolly be my last step.
maximizing your stock cooling system should be ok for day to day driving (unless your in heavy heavy stop and go trafic)
Old Jun 25, 2008 | 02:00 PM
  #140
kelsodeez's Avatar
UNBANABLE
what kind of oil are you T1R guys running? i put some greddy 5w40 oil in my car. its the greddy type 2 oil made for aftermarket turboed engines.
