T1R 50s v2 or Spoon N1 help
Old May 5, 2008 | 08:57 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Originally Posted by George02
omg.... spoon is not loud! and the ver.2 looks like the stock axle back. can some1 please post pics so we can compare?
With a Bpipe, jes it is. A Bpipe and cat-delete.
Old May 5, 2008 | 09:24 PM
gmane's Avatar
How about with a b-pipe but stock cat? still say its a 7 - 7.5?
Old May 5, 2008 | 11:46 PM
sumo's Avatar
maybe my 7 is different from yours. i'd say j's maybe 7. spoon 7.3 lol
Old May 6, 2008 | 12:35 AM
spoonek4's Avatar
Originally Posted by gmane
I would use it for when my parents are in town or maybe my girlfriend..
So your parents & your gf isn't in town all the times then? If that's the case, swap the stock muffler back man! That's just a 5min job to swap a muffler and u will be able to talk to your gf & your parents without raising your voice.
Originally Posted by GD3-Fit
i really would like the full spoon exhaust which would run me over 800
but if i get the invidia catback it's 430 shipped and plus i've owned
invidia for my s2000 and i know it will probably sound good
U really cannot compare a 2.0L DOHC VTEC block with a damn little L15 that we have in our car. Most of the SOHC D15/D16 runs stronger than a L15. And most of us know a dead slow small 1.5/1.6L civic looks stupid with a screaming loud exhaust(hey is the car moving YET!?), it's just the same case on our Fit.
As I remember the Invidia catback isn't full stainless steel right? 800ish is really reasonable for a full stainless steel catback. I still remember those days that a lot of us need to pay over 1k+ cad for a 5zigen fireball or border304 speed, APEXi N1 catback etc.
Originally Posted by sumo
do you hear the above from ppl with b-pipes or no b-pipes? It makes a huge difference.
I would say from what your comparing the v2 vs n1. I would say the performance is there in both exhausts. If you want a quiet deep tone exhaust, go for the 50s v2. If you want something louder, go for the N1. either way you cant go wrong.....
Agreed. If u are only going to get a SPOON N1 muffler and no plan on getting aftermarket B pipe, and header etc, then it really won't be that loud. However it's another story if u're gonna get header & b-pipe in the future.
how about this on a scale from 1 - 10 (10 the loudest) rate both exhausts Spoon N1 & T1R V2 oh and throw the J's 50 in there cause i've heard that so i can get a good idea..
OK let's do it this way, bolt on muffler(muffler, no header, test pipe, B-pipe) wise:
T1R 50s ver.2 muffler: 1/2
SPOON N1 muffler:
J's racing muffler: (higher pitch compare with the SPOON N1 due to the Ti material)
catback exhaust wise(with resonated SPOON b-pipe or T1R b-pipe, stock header & stock cat):
T1R 50s ver.2 catback: 1/2
SPOON N1 catback: 1/2
J's racing catback(can't really compare coz the J's Ti b-pipe have no resonator??): 1/2
If you got test pipe & header, add another one or two depends if u have only one of them installed or BOTH!
IMHO, I will go for either a header or test pipe on a Fit but not going for the full header back exhaust. I do not want to sacrifice the low end & throttle response with a header back setup(yea it's shitty enough). If you are running SRI/CAI intake, u might wanna think whether or not u are going for a header back or not.
Just FYI gmane, ever since I swapped my SPOON oval type muffler back on to my car I can notice a louder exhaust note compare with the 50s ver.2, especially after the exhaust's warmed up. T1R is better from mid-high rpm range, and my SPOON sports oval type muffler is better from low-mid range.
Old May 6, 2008 | 01:50 PM
gmane's Avatar
Thumbs up
SPOON N1 muffler:
This was really detailed !!! so you'd say go header/stock cat/b-pipe/exhaust or just header/stock cat, stock b-pipe/exhaust? I was thining of going with my first option.. what do you think?
Old May 9, 2008 | 12:25 AM
spoonek4's Avatar
If you want it quieter, just get aftermarket header & a 50s Ver.2 if u don't wanna swap muffler when u need to give your parents a ride. That should improve the flow but u won't lose too much low-mid range. If u like it a bit louder & don't mind swapping mufflers then go for the SPOON N1 bolt on muffler with a header. I believe the gain is identical between the two.
Header+stock cat+aftermarket catback will be ideal for road courses with longer straights & high speed corners. Not too practical the track has a lot of tight turns & uphill sections.....
Old May 25, 2009 | 09:50 AM
amelsportfit's Avatar
SPOON N1 muffler:
where'd you buy your spoon oval type muffler? i think that will be the best choice for me.. then go for b-pipe ummm.. haha
SukebePAUr
22
Oct 23, 2008 05:53 AM
jdmspoonfit
Jun 18, 2008 01:12 PM
FitnessJay
Feb 13, 2008 01:51 AM
JDM_FIT
Sep 27, 2007 11:09 AM
