Dyno results!!
Old Sep 17, 2008 | 05:55 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Originally Posted by YeeFit
Yup. From what I heard Hondata won't be releasing anything for the L15A. The only Hondata you will be able to get is the reflash that will go with the Kraftwerks kit.
They wont release anything because the L15 runs lean enough with bolt ons.
Old Sep 17, 2008 | 06:05 PM
one bad dx's Avatar
Common sense says its lean but since the boost is so low its fine. The HKS kit runs similar AFR's.
IMO, Id have it retuned to a safer AFR. Both the HKS and T1R kit run 13.0 ish AFR's at the highest. Both have been tested for a while and havent shown signs of detonation.
Compression and leak down tests were done.
Great point! Did not take into effect the low boost levels. I'm too used to seeing anything under 10 running on an FMU at best lol. Usually 12-15lbs is what I've seen for years on B-series lol. Gotta change up teh habits
Old Sep 17, 2008 | 11:37 PM
jvm051's Avatar
I don't think low boost levels make it ok to run with A/F' in the 13's What happens if you get shitty gas, or its really hot out, something gets past the fuel filter and creates a blockage in the lines, etc. With a boosted car you should be lower that that. Unless you want to blow your engine, if you go Forced induction, you NEED to get a dyno tune with a wideband A/F gauge, or at minium get a Dyno baseline to see what the canned tune has your A/F at. Every car is different. Im guessing the market for Forced induction Fits, is quite a bit lower than say a Mustang, so you would not hear of somebody popping the motor on a Fit, after a all out blast down the quarter mile, as much as a popped motor on a Mustang, with the canned tune, but I would not take my chances. Anybody know what the size of the stock injectors and fuel pump are on the Fit? I'm really curious to see what they are rated for.
Old Sep 17, 2008 | 11:40 PM
jvm051's Avatar
All the more reason to have Hondata create a reflash to compensate for lean situations after adding bolt-ons. Also could get rid of DBW throttle lag, without having to purchase overpriced throttle controlers.
Old Sep 18, 2008 | 12:04 AM
YeeFit's Avatar
I'm pretty sure the stock injectors are 185cc. The injectors in my T1R kit are 310cc.
Not sure on the flow of the stock fuel pump, but from what I've heard it'll handle up to 200hp.
Old Sep 18, 2008 | 08:33 AM
one bad dx's Avatar
Getting some good info in this thread. We can debate all we want but lets try to keep it to a minimum and focus on the real info........Lets see some more dyno charts!!
Old Sep 26, 2008 | 12:58 PM
one bad dx's Avatar
Anybody got any new dyno's?
sam21
130
Jul 2, 2014 12:17 PM
ModR
Feb 20, 2012 09:56 PM
JoeF
Aug 8, 2009 12:44 AM
projekz
Dec 10, 2008 10:46 PM
waijai
Texas Community
15
Oct 29, 2008 04:11 PM
