KraftWerks Supercharger Kit Info v4.0
Old Apr 30, 2009 | 03:44 AM
  #441
revd34's Avatar
i'm going to upgrade my spark plugs. for those of you guys that have upgraded your spark plugs (or if you know), should i do 1 step colder? what brand do you recomend?
Old Apr 30, 2009 | 06:48 AM
  #442
Texas Coyote's Avatar
NGK V-Power Copper Core. I would go one or maybe two heat ranges colder, depending on how much gap you set them at and the type of driving that you do. I am not sure about the part number, but let me know what it is if and when you find out....I ordered a Kraftwerks system 2 days ago.
Old Apr 30, 2009 | 08:22 AM
  #443
Wave's Avatar
Forced Induction & Spark Plugs...
I went thru this awhile ago when I was getting my KWSC installed. Seems everyone on the net recommends going at least 1 step colder from the OEM plugs, problem was (for me at least) what exactly is "1 step colder"?
I made the switch from OEM to NGK Iridium IX (BKR7EIX-11, Stock No. 6988) and have had zero issues that I am aware of since installing them.
Old Apr 30, 2009 | 08:40 AM
  #444
Hotter plugs retain heat in the combustion chamber , while a colder heat range plug dissipates heat more rapidly.... Supercharging creates more heat in the combustion chamber than a naturally aspirated induction by adding more air (oxygen) and can require colder heat range spark plugs to prevent pre detonation damage.
Old Apr 30, 2009 | 08:50 AM
  #445
Wave's Avatar
Thanks!
What I meant to say was:
"What brand/model # plugs would be considered 1 step colder from the stock OEM plugs?"
I think there's a whole thread floating around here on that.
Old Apr 30, 2009 | 09:37 AM
  #446
If you use NGK or Denso spark plugs you will find that the lower the plug number is the hotter the plug and colder plugs will have higher numbers.... I use NGKs with a heat range rating of 8 in a 4.3 G.M.C. V6 that came with spark plugs that cross referenced to a heat range of 6.... I had put a Mallory Hi-Fire ignition box on it and it pinged like crazy until I got the right heat range plugs in it.
Old Apr 30, 2009 | 11:13 AM
  #447
MNfit's Avatar
I had to step down to colder plugs a week after I had the Kit. I went with NGK's stock No. 6130
Old May 1, 2009 | 11:54 AM
  #448
OJRKraftWerks's Avatar
Former Vendor
Denso IK22 or NGK BKR7EIX are one step colder plugs that should work great in your systems. We will soon be stocking Denso IK22 and IK24 spark plugs.
Be sure that you purchase resistor spark plugs. Non-resistor "race" plugs could cause havoc to your electrical system.
I hope to have some updates on the High-Boost system shortly. We have added content to the system that everyone will be happy to see. We should be able to show you guys WHAT we are doing for the High-Boost very soon!
-Oscar Jr.
Old May 1, 2009 | 11:56 AM
  #449
keepitpg's Avatar
i love college
-Oscar Jr.
Will there be an AT high boost kit?
Old May 1, 2009 | 12:14 PM
  #450
Wave's Avatar
Even though they said there was no plans for one, I still hope they do.
Old May 1, 2009 | 12:31 PM
  #451
keepitpg's Avatar
i love college
don't we all..
Old May 1, 2009 | 12:36 PM
  #452
Wave's Avatar
don't we all..
Hey, if begging helps....
PLEASE PLEASE PLEASE consider a hi-boost A/T kit! I'm sure it can be done as there is currently somebody in FitFreak already doing it.
: hyper::h yper:
Old May 1, 2009 | 12:38 PM
  #453
keepitpg's Avatar
i love college
there isn't one person with an AT kit that wouldnt mind an extra 3-5 psi!
Old May 1, 2009 | 01:33 PM
  #454
MNfit's Avatar
im thinking that even if they dont make one for the AT specificly, the MT kit could be adapted to work on the AT cars.
Old May 1, 2009 | 03:37 PM
  #455
Wave's Avatar
Just reading in between the lines perhaps?
OJRKraftWerks stated:
From the KraftWerks AT page:
With the addition of a Test-Pipe to this kit, the injector upgrade or Hondata Reflash is required.
Old May 1, 2009 | 04:10 PM
  #456
dewthedew's Avatar
what about injector upgrade AND hondata reflash.
Old May 1, 2009 | 08:01 PM
  #457
My super charger is on its way... If anyone that has done their own installation can offer any advice that could be helpful, please feel free to clue me in.... Any advice is welcome and would be greatly appreciated.
Old May 1, 2009 | 10:07 PM
  #458
leonine's Avatar
take your time especially with bending the brake lines.
there very little room in there as i am sure you already know. you will need to remove the exhaust mani but dont take it out (unless you are planning to wrap it which isn't a bad idea) just put it to the side. remove the top piece of the intake mani as well. i removed the whole thing when i originally installed mine because i was swapping injectors also. This is of course if you are planning on installing the rotrex from the top otherwise you would need to remove the passenger side axle.
don't rush it.
Old May 1, 2009 | 11:18 PM
  #459
Thank you for your response leonine. I have a very messed up back, so I think I am going to have to remove the axle and crawl under....I looked at the instructions on line and they look pretty good. I am surprised at this time that so many are spending so much to have someone else do the installation..... It's almost like buying a model car and paying someone to put it together for you.
Old May 2, 2009 | 04:09 AM
  #460
revd34's Avatar
so another quick question. my car feels faster when i press down on the gas pedal 75% than when i press it down 100%. does anyone else have this problem? it can't be the drive by wire because i have the blitz throttle controller
