what is the max boost for stock L15A
Old Nov 26, 2010 | 04:37 PM
DiamondStarMonsters's Avatar
Originally Posted by kylerwho
there are no real lower compression pistons. the forged units now made are running the same compression as stock i believe.
no one is running higher boost on the ge to really test their melting point but i wouldnt be suprised to see you get around 240hp before self destruction happens.
I am pretty confident that with ~$500 in fuel system upgrades like a 190lph walbro pump, an adjustable pressure regulator and new injectors coupled with a larger GT28R/GT30R MHI 14B/16G sized compressor pumping through a nice large intercooler with C16, E85/98 or Meth + 93 pump gas achieving a reliable 240whp should not be a problem if you maintain strict maintainence.
You can do a built bottom end in a GD for less than $1500, that with ~$500 in sleeves would see you safely past 300whp.
There are in fact lower compression pistons, Mahle or Wiseco make pistons on request in addition to the 9.8:1CRs they have off the shelf..
Wiseco L15A 73mm 9.8:1 Pistons: Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST
Boost is not the limit, boost is but one of the dials you can turn in tuning.
The GT25 being too small and inefficient where our engines use them is a big issue, because @ 12psi flowing only ~22-25lbs/min they are already blowing hot air, and high IATs along with the rigid engine management provided by HKS on a high compression engine are what causes detonation. It looks like lean detonation too.
The information from the service manual that Lyon posted in my tech thread suggests the factory fuel system wiring, lines, fittings, make it tough for the already undersized pump to keep flow up when overall fuel pressure exceeds 63psi, so 52psi BFP + 11psi Boost.
The below illustration shows a typical electric fuel pump curve. A modern day multi-port fuel injected engine uses injectors designed to operate at from 45 to 60 psig (pounds per square inch gage). At 45 psig the illustrated pump will flow about 45 gph (gallons per hour). At a conservative 12 HP (horsepower) per gallon of gasoline that’s enough fuel to support 540 HP. Now if the same pump must work at say 75 psig (if we boosted the engine to 30 psig we’d need 75 psig to compensate for the increase in manifold pressure) it will flow only 35 gph or enough fuel to support 420 HP. That’s a decrease of 120 HP
Fuel Pump Head vs Flow vs Voltage | Blowerworks.biz
MKIV.COM - Fuel Pump Upgrade Guide
When groups like Injector Dynamics or Fuel Injector Clinic sell a batch of injectors they sell them based on their flow rating @ 3bar, ~43.5psi.
From what I have found on many systems, when you raise or lower BFP, there is a near linear trend in the flow volume (I'm sure there is some coefficient for it depending on fuel system factors)
Injectors rated to flow of 185cc/min @ 43.5 psi (usually within .5%) across a batch of 4 from either company, can actually sustain ~215cc/min @ 52psi BFP. This is using a 100%IDC, most manufacturers recommend 80% IDCs max. So that means even 80% @ 52psi is only 172cc/min
At 5psi boost on top of a 52psi BFP, for a total 57psi fuel pressure on a 1:1 ratio pressure regulator with an adequate pump, lines, filter and rail, those same 185cc/min injectors could flow 229cc/min @ 100%IDC or 183cc/min @ 80% IDC.
The KW kits seem to offer 195cc/min and 310cc/min units as well, but 195cc/min @ 80%IDC and 52psi BFP is only 193cc/min, or 241cc/min @ 100% IDC
310cc/min @ 80% = 307cc/min
310cc/min @ 100% = 383cc/min
For 11psi boost:
That puts us at 242cc/min on the 185s @ 100% IDCs and 194cc/min @ 80%
On the 310s we get 406cc/min @ 100%, and 325cc/min @ 80%.
https://www.fitfreak.net/forums/fit-...er-meth-7.html
Nothing has visibly melted in that picture BTW, that is just a snapped conrod.. Unless the dome of the piston melted and he did not show a picture of that. But there would likely be slag from the piston melting on the wrist pin and conrod its self were that the case.
There are a couple great points, but there is so much misinformation in this thread I don't even know where to start. From the carnage pics it looks more like one of the conrod bolts yielded after he bent the rod a bit under predetonation and that led to the ensuing failure..
IATs, AFRs, compression, fuel quality and timing make up the rest of the equation. Boost is ambiguous in this equation when you don't have the other numbers.
Those stouter conrods and a larger compressor would allow him to make more power at the same boost on a more conservative tune.
Not only would you have a less streetable power curve (torque specifically) N/A, because of the cam and other VE mods needed but to even reach your power band you would have to wind to the moon to make 220whp. The piston speeds, the friction that comes with it on the rotating assembly and the demands on supporting systems like the water and oil pumps, accesories, valvetrain and drivetrain components shifting at the stratospheric redline required to churn out 200whp+ from a 1.5L.
This would be far more detrimental to longevity than boosting the engine and maintaining the stock redline to create the same amount of power.
Sorry for the essay but it is frustrating to see so many half truths, speculation and whole lies stated so confidently as fact.
Old Nov 26, 2010 | 10:56 PM
SilverBullet's Avatar
Ive seen a stock K20a2 run 20 pounds of boost with c16 racing fuel. The engine was thrashed and tuned and ran the quarter mile 30 times or more with no problems except for the pipe blew off a few times where it was clamped but most of the piping was welded. We check the plugs a few times at the track and richen it up a little but had more traction problems than engine problems. You cant run more than 6 psi with pump fuel unless you lower the compression but if you use the right fuel and the right tune, I can see it running 10-14 pounds of boost easy. You also have to remember that a stock cam is different than a boosted cam. Stock cams dont have a lot of overlap to bleed psi off and because a boosted engine needs overlap to help scavenging to help it breath better at higher rpms its limited to how much power it can make safely.
Old Nov 27, 2010 | 08:08 PM
kylerwho's Avatar
spoon fed
i appreciate the essay. helps people not in the know (like me) build knowledge.
i used melted as a figure of speach since this is not an engine specific forum and most people are not engine builders or mathematicians.
most people equate boost pressure to the limiting point of this motor. (everyone assumes they are using a t25 since no one is running custom kits yet.)
Old Nov 27, 2010 | 09:17 PM
Sorry I didn't mean to single out your post but I am glad that it was a helpful in some capacity.
It's still hard to use boost as a limit, even on a T25, because there are more than a few different configurations under the designation T25, GT25 and GT25R. Those are all basically the same compressor with different turbines and turbine housings. These things change the compressor maps efficiency islands as well as where in those islands we can use.
Old Nov 27, 2010 | 09:23 PM
kylerwho's Avatar
spoon fed
indeed i know where your coming from.
i have contacted eagle for sleeving my l15 block and i think i will release a suprise motor that will test the limits of the flow capability of the head.
porting seems to be a big no no on this motor however due to material thicknesses.
i did take a spare head and have it x rayed to see if that was possible.
blackgd3
Nov 11, 2023 01:55 PM
CarbonTek
Feb 21, 2019 11:18 AM
clanbuster
32
Feb 10, 2013 06:42 PM
sum76
Mar 23, 2012 10:26 PM
clanbuster
Apr 17, 2010 07:27 PM
