Turbo GD : What clutch are you guys running?
Old Nov 26, 2010 | 08:46 PM
gd311's Avatar
Im using Exedy stage 2 clutch. it is pretty good in terms of power transfer to the wheel. the only thing i need to do next is to harden my engine support or install a engine damper.
Old Nov 30, 2010 | 03:12 PM
Previc93's Avatar
i have a stage 2 exedy and it has worked pretty good. a week after i put the clutch in my mounts went bad. couldnt handle the transfer of power. so i got innovative 85a motor mounts. but overall im pretty happy with what i got. i have to get another one now though. used it for bout 35k miles... time for a new clutch.
Old Nov 30, 2010 | 04:01 PM
DiamondStarMonsters's Avatar
Granted the Fit does not have a whole lot of torque, but some of you will be seeing in excess of 175lb-ft, and this makes it easy to slip or even glaze the clutch.
This is even easier with an aluminum flywheel, you can also overheat and warp the friction surface on an aluminum wheel. Especially those with replaceable friction steels like some Fidanzas, because the metals expand/contract at dramatically different rates.
I would really like to see a Chromoly option from a group like ACT..
As long as you dont have a kevlar disk/aluminum flywheel combo though you should be good as long as you let the clutch cool down for a minute or two between hard pulls.
If you do glaze your clutch you can sometimes re-bed it by driving gingerly for a hundred miles or so.
A six puck sprung disc with the stock pressure plate and a stock flywheel would be best for street/track guys.
This way you have almost a full face disk, but you save weight with the pucked design, and having the same clamping force distributed over a smaller area means higher torque capacity with a streetable clutch pedal/engagement.
The lighter pucked discs will help shifting at 6k+ as well, less dragging.
Old Feb 17, 2013 | 11:55 AM
bana1988's Avatar
any particular recommendation as far as a specific manufacturer/model...
Old Feb 17, 2013 | 01:59 PM
How much torque are you making?
Old Feb 21, 2013 | 09:49 AM
gynosis's Avatar
Picking up some occasional slippage from my OEM clutch, got an Exedy Stage 2 clutch waiting in the box.
OEM clutch is holding up surprisingly well though...
Old Feb 24, 2013 | 05:58 PM
k24a2fit's Avatar
I use Bully Performance Clutch, no slip with drag radial! Really good clutch for drag and time attack but not really cool for daily driving
Old Feb 24, 2013 | 06:28 PM
Previc93's Avatar
Comp clutch stage 3 i believe.
Old Feb 6, 2014 | 08:11 AM
unclepowers's Avatar
F1 racing stage 3 six puck clutch with a ACT stage 3 pressure plate. And it hauled ass for three years until my gearbox got thirsty and decided to take a healthy drink of water. Which messed up the diff
Old Feb 15, 2014 | 03:38 PM
gynosis's Avatar
Exedy Stage 2 racing clutch lasted about 10 000km's, unimpressed :|
Fitting a Clutch Masters FX-300 clutch kit + flywheel as we speak. Will report back once it's been bed in.
cnordt24
May 10, 2015 10:30 PM
cnordt24
Jan 28, 2015 08:27 AM
fitisbamf
Dec 15, 2009 05:56 PM
ride_the_pony69
Sep 10, 2007 02:36 AM
sLiVeRwOrM
15
Aug 8, 2007 10:44 PM
