where to buy turbo manifold for internal wastegate T25?
Old Oct 16, 2010 | 03:15 PM
  #41
kylerwho's Avatar
spoon fed
why wouldn't you just buy a log manifold and put a block off plate so that you can run an internal wastegate.
Old Oct 27, 2010 | 02:35 PM
  #42
R@ymun2's Avatar
Bump! Any updates kelsey??
Old Oct 27, 2010 | 04:50 PM
  #43
kelsodeez's Avatar
UNBANABLE
yea. fuckin turbo i was given has a cracked exhaust side housing so i might just get a cheapo 250 dollar T25 to run.
Old Oct 27, 2010 | 07:31 PM
  #44
R@ymun2's Avatar
Damn that sucks dude
Old Nov 24, 2010 | 02:18 PM
  #45
R@ymun2's Avatar
Bump! Kelsey you boosting yet?
Old Nov 24, 2010 | 02:53 PM
  #46
DiamondStarMonsters's Avatar
Just make sure it has that 5 bolt pattern on the exducer side if you already have a corresponding downpipe.
Or you can switch to a 4-bolt MHI outlet if you wish, and then use a segregated wastegate recirc down pipe, which would help with boost creep through smoother flow and less back pressure.
Which would make your whole setup more efficient at the same boost, which is a good thing on pump gas.. especially if 91 octane is your only premium option, like in many parts of the country
Old Nov 24, 2010 | 03:17 PM
  #47
kylerwho's Avatar
spoon fed
send that turbo up here and i will weld that crack shut.
supersuave89
18
Nov 15, 2016 07:11 PM
B.A.M.
14
Aug 19, 2009 06:44 PM
dave brown
May 27, 2008 12:35 AM
quangalang
21
May 17, 2008 04:10 PM
gd_shane
Apr 3, 2008 10:49 AM
