front strut bar with kwsc intercooler
Old Apr 20, 2011 | 03:36 PM
Jesse's Avatar
Are you familiar with "knock retard"?
You can run on 5 or 10psi, but you want air flowing over the charge cooler if you are going to bother installing one and spending the money on it.
Nope, never heard of it. Ive only been turbocharging hondas since 1994, so im pretty new to this game.
and since you are all so knowing, tell me how have I put 40K miles on my fit since it was @5lbs and 15Kmiles since it was @10LBS WITH IC AND NO SCOOP? guess what? ZERO ISSUES
Old Apr 20, 2011 | 03:56 PM
DiamondStarMonsters's Avatar
Reading comprehension.. try it sometime.
Old Apr 20, 2011 | 04:49 PM
feared's Avatar
no one's denying the fact that u can run the 10lb kit without a scoop.
Old Apr 21, 2011 | 01:31 AM
TunaDaMan's Avatar
So the OP has an answer, you can have the intercooler with the KWSC, and a strut bar, but you lose the ability to use the scoop unless you modify it. can we close the thread now
Old Apr 29, 2011 | 11:13 AM
THEproFIT's Avatar
I have nothing nice to say in this thread....so edited it is.
Old Apr 29, 2011 | 12:22 PM
TunaDaMan's Avatar
Oh I'm sorry you are a moron, but i can't help with that =-(
but here like your first post said pics and suggestions,
(PICTURES BELOW)
Size:  85.8 KBName:  IMG_0275.jpg
Oh look I do have a scoop (sorry not THE SCOOP) and a strut bar OMG!!!!
AND YES OMG WHAT DO I SEEE, like i said before and what was said... if you can extrapolate in your head from the pictures. the strut bar would sit in the way of the kraftwerks scoop, (here comes the suggestion-->) so unless you modify it you can't use it to direct air the topmount intercooler.
Being as ass like you won't get you answers quickly like you would like, it just makes people think you are an ass
Old Apr 29, 2011 | 01:56 PM
Originally Posted by THEproFIT
ONLY PPL who ACTUALLY mounted a strut bar WITH THE SCOOP need to reply........all other post/replies mean U R A MORON who's replies r unwelcome
I DID CLEARLY STATE THAT ANY USELESS REPLIES R TO BE CONSIDERED AN ATTACK SO THIS IS MERELY IN SELF DEFENCE!!!!!!
RICERS F OFF!!!
You got your answer. Now learn how to type you dipsh*t. I think your caps lock key is broken.
Old Apr 29, 2011 | 02:11 PM
Sid 6.7's Avatar
Why so serious?
Here is your warning : If you plan on staying around here at FF.net you need to be a bit less aggressive.
Creating a thread where you ask for help, but then command people on what they can or can't post is not gonna fly. Insulting them on top of that is gonna get you the banhammer upside the head quick fast and in a hurry.
So chill. And here's a week for you to think it over.
Old Apr 29, 2011 | 02:29 PM
gimme's Avatar
Master FitFreaker
back on topic, fellas. all cleaned up
gj, Sid
Old May 1, 2011 | 01:21 PM
lcq4blackstar's Avatar
This response has nothing directed toward you but to let people know these Rotrex units run very cool, I've watched my IAT's at no more than 85c so far in day to day driving. 65 -70 degree days here in Southern California. This is on 10psi no intercooler at the moment, I will be on a front mount in the next month or so. The top mount included in the high boost kit was picked for ease of implementation/installation. If you have a top mount in the engine bay only being fed by the little scoop into what looks to be a 2" accordion tube that has to bend 180 degrees you aren't seeing any help until highway speeds if at all... There is a loss of like 25% for every 90 degree bend in airflow, a small accordion tube isn't helping anything ether. The heat soak is also an issue in this location. Only real solution would be to vent the hood with an induction scoop that sealed over the intercooler to make it of use.(think Subaru)
As for the original poster, there are countless things you could do that would give you better suspension/body performance over the almost cosmetic bar you want to install.
Just to name a few, have you done:
lighter wheels?
performance tires?
coilovers/stiffer spring rates?
motor mounts?
control arm bushings?
better top hats?
I could probably list a page of more benifical things that a 2 point non-fixed aluminum tower bar...
Benggolf
15
Feb 28, 2011 02:37 AM
Evan_2k
Feb 20, 2009 12:49 PM
vtecdreamer
Nov 11, 2007 09:52 AM
Firebat666
Oct 6, 2007 09:07 PM
Fit Heaven
Mar 27, 2007 11:54 AM
