What is TRUE (Don't delete this ADMIN!!)
The Older B-Series engines spin counterclockwise! The Transmission makes up for this and brings it Forward rotation! When i stated that it is backwards was not the Manifolds thing! I'm a Mechanic and a Honda performance Freak!
I understand that some ADMIN person deleted what i said so as not to start controvery in a thread that it didn't pertain to, so now i'm stating it in a separate thread! Go look it up yourself! If i'm wrong, (Which i'm not) You can delete my Thread! (but PM me your opinion!) The B-series in a fit would take a bit more customization b/c of mount locations on frame! and engine positioning for the axles to fit through the suspension! Just a heads up! |
I didn't want to get too technical, It might spark controversy. But i figured that people reading an engine swap thread would be alittle versed in Honda engines......
honda motors have been what's known as a transversed mounted motor for a long time, atleast until teh V6 came along, once the K-series hit they were facing a change from a transverse mounted motor, if you look at any new honda now you'll see that they are nolonger mounted that way ofcourse.
TOMH, transversely mounted engines are MOST Front Wheel engine/transmission assemblies as placed in most FWD cars.
Transversely mounted just means instead of front to back positioning, it's side to side positioning. And the V6 honda accords are also Transversly mounted by the way! The K series is also transversly mounted. The only FWD vehicle by honda that i know that is not transversly mounted is the 91-95 Legend. Strange Transfer case that went forwads and the differential wrapped around the oil pan! Just a heads up!! |
All legend an Rls up too the 2005 were longitude mounted. When the RSX(K20) engine replaced the B series of the old interga they reversed the mounting to try to prevent rampant engine thefts.
Transversely mounted just means instead of front to back positioning, it's side to side positioning. And the V6 honda accords are also Transversly mounted by the way! The K series is also transversly mounted. The only FWD vehicle by honda that i know that is not transversly mounted is the 91-95 Legend. Strange Transfer case that went forwads and the differential wrapped around the oil pan! Just a heads up!! though i know your right about FWD V6, since they are out of the norm. |
Ever notice how the old V6 Saturn Vue was a joke, yet the Honda V6 powered one is very well rated in buyer’s guides? |
| All times are GMT -4. The time now is 04:12 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
