Bolts for test pipe????
Bought a T1R test pipe from a member on here and was wondering if anyone knew what kind of bolts I'm going to need to install this beast? I've mis-placed the extra bolts that came with my cat-back exhaust. Any info is appreciated.
thanks, ~Demon |
Can probably just use exhaust spring bolts. My b-pipe didn't come with anything to bolt onto my muffler so I went to the local Kragen/pepboys/autozone and bought 2. Or if you need ones that will fit into your header's threading you can probably just order a couple from a honda dealership.
someone told me to use the spring bolts from the the stock cat... I'm not sure I know what a spring bolt is :confused:
Btw... I'm using factory exhaust manifold if that makes any difference?
The stock spring bolts that hold the test pipe / cat to the headers looks like this:
http://www.jonesland.com/evo/Images/...npipe_Bolt.jpg You can reuse the ones holding your cat to the headers at the moment. As for the test pipe / cat to midpipe connection, I had to buy 3 regular bolts and nuts for it, the bolt was about an inch long and iirc was an m8 or m10 size. The stock cat, iirc, has studs pressed/welded in but the test pipe doesn't. |
Use the stock spring bolts at the exhaust manifold, and purchase new bolts for the other end due to the stock cat bolts being pressed on. M6 i believe available at Lowes. I will be posting a DIY soon when I get home
Originally Posted by Bthasht
(Post 1000633)
Dis-regard last... I just now saw the link in your sig....
