Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   Fit Engine Modifications, Motor Swaps, ECU Tuning (https://www.fitfreak.net/forums/fit-engine-modifications-motor-swaps-ecu-tuning/)
-   -   Anyone know where the Fit's "Moby Dick" is? (https://www.fitfreak.net/forums/fit-engine-modifications-motor-swaps-ecu-tuning/7522-anyone-know-where-fits-moby-dick.html)
jrlnc Aug 4, 2006 06:13 PM
I've mentioned elsewhere that I was buying a Scangauge. Well, it arrived today and I want to plug it into my Fit, but where?
The outlet is called the "Moby Dick", or OBDII or OBD2. I thought it would be near the interior fuse panel, but I pulled the fuse panel cover off and I don't see it anywhere. I'm not really sure what it's supposed to look like either.
Any ideas? I'm stumped. :confused: :confused:
tubaman Aug 4, 2006 08:15 PM
edit - thanks to a post on the Fitit Yourself Fitfreak forum I found it - wasn't easy! There is absolutly no mention of it in the owner's manual.
under the dash, driver side, near where the console passes under the dash, just above the accelerator pedal. You can feel a rectangular plug set into a shallow recess. I don't know if it is totally compatible with all OBD2 scanners - there is some further discussion on Fitit Yourself forum.
sam Aug 4, 2006 09:09 PM
right side of the drivers side under the dash easily accessible.
Note: Do a search for several prior threads
https://www.fitfreak.net/forums/show...ighlight=ODBII
https://www.fitfreak.net/forums/show...highlight=ODB2
https://www.fitfreak.net/forums/fit-interior-modifications/5928-greddy-informeter-fit-no-go.html
gsilvers Aug 7, 2006 02:30 PM
Yea I posted this earlier in a bad spot but really if you're sitting in the drivers seat reach up and right where your right knee is and up theres the port.
dacalac Aug 7, 2006 04:52 PM
since it's already been covered I'll go ahead and lock this down. =)
© 2026 MH Sub I, LLC dba Internet Brands
