Hks turbo kit for 2007-2008 gd3
Old 07-25-2017, 01:05 PM
sleepingAwake's Avatar
Just picked up a base gd3 fit and separately a used hks turbo kit
Got the install manual from the good folks at Kaizen tuning.
Probably going to change some things up like the oil drain setup. Hks has it going to the oil drain bolt below the oil level. Ill look into installing a fitting above the oil level.
I dont really have any questions yet but im sure i will in the meantime stay tuned.
Pics and more to come.
If anyone has info to offer please post it.
Link to install manual https://drive.google.com/file/d/0B18...w?usp=drivesdk
Old 07-30-2017, 11:07 AM
devmail's Avatar
Cool, nice find! Looking forward to your results.
Old 08-10-2017, 07:09 PM
This may end up being a dup post but lets see. Tried posting from my phone and it doesnt seem to saving.
Got some work done the other day.
Pretty sure the windsheild washer bottle gets deleted. Not on my watch. A heat gun and dishwasher hose take care of that issue.
Left front crash bar support was crushed at some point. Made a new one from scrap and painted it the wrong color blue.
Old 08-10-2017, 08:04 PM
GAFIT's Avatar
Nice work! Great find on the HKS kit.
Old 08-11-2017, 05:36 PM
Ended up brazing the HKS exhaust manifold.
It was cracked right through the middle. I was going to mig weld it but didn't feel like buying stainless wire and different gas.
Old 09-26-2017, 08:07 AM
GAFIT's Avatar
This thing on the road yet? How'd it turn out?
Old 11-14-2017, 12:36 AM
Bongobennie's Avatar
Here’s my oil return
Attached Thumbnails Hks turbo kit for 2007-2008 gd3-17185924-3500-4486-a222-c7db58ea17c8.jpeg
Old 11-14-2017, 11:26 AM
Nice job on the oil return. Wish I had a TIG setup.
Car is on the road but still just NA. Turbo has a little more shaft play than I like but I might just throw it on anyway.
However the big hold up is money to buy another engine.
I cant see the sense in putting a turbo on an engine with 215k.
My bright idea will be to pickup a used engine with half the mileage, give it a refresh and fit all the turbo stuff with it on a stand. Should be occurring sometime this winter.
Old 11-14-2017, 11:33 AM
GAFIT's Avatar
I'm about to turbo our 190k mile motor. Why not? It will either hold or not. Might as well find out. Bought a Top Fuel kit. Not impressed and the turbo has been replaced with some eBay junk, but I'll put it on and see how it does.
Did you get the engine management stuff with your kit? The TF kit came with an HKS F-con thing, but I don't plan on using it. Going straight to Hondata.
Granted, we have the luxury of not depending on the vehicle. Different than if it were a daily still.
Old 11-14-2017, 04:02 PM
In my opinion it just makes more sense to boost a younger motor.
The added convenience of having the motor out of the car while I install the turbo and modify the oil pan with a proper return further reinforces this thought process to me. I'll take the time to replace anything leaking on the newer motor and give it a once over while I'm at it.
Plus I can continue to drive the car in stock form without worrying about a deadline. Junkyard motors seem to run around $300-$700.
Contemplating head studs but I need to think about it more. The rods are probably the weak link in this equation.
I did get the HKS FCON and wiring harness but wont be using it in lieu of HONDATA. Car will be self tuned.
Old 07-04-2018, 07:40 PM
bump from the dead
Little guy had more shaft play than I was comfortable with.
Feeling good now. Soon...
Old 11-24-2022, 08:26 PM
TurboFit has been completed and running for 2 weeks. 4.7 peak boost. Just using the internal wastegate for boost control. I'll purchase an EBC after I've worked the street corners a little harder.
Tuning is going well. Innovate wideband shows I'm hitting my AFR target of 11.5 in boost. 410cc RDX injectors only hitting 50% duty cycle. Car drives more confidently. Easier to pass. MPG doesn't seem down much but I haven't measured properly.
Hacked together a downpipe from a Bosal cat meant for a 96 Subaru impreza. Filled the old and broken motor mounts with 60a urethane. Got a temp gauge pod printed out of PLA for my wideband. ABS later now that I know it fits.
Old 03-28-2023, 03:11 PM
BooSTDFIT's Avatar
(New to this community so I don't know how to use just yet) I have an 08 sport. Where can I find a turbo kit?
Old 03-28-2023, 04:59 PM
GAFIT's Avatar
Greddy, HKS, TopFuel, etc discontinued their kits over a decade ago.
If you are really interested in a turbo kit, join FitFreaks on Facebook and hit up Ethan Adkins. He custom makes kits based on what the user has for goals.
Old 04-29-2023, 03:06 AM
It is I the procrastinator.
TurboFit has been up and running with a very safe base map made by me since early December 2022. A couple of weeks ago something clicked with my understanding of tuning and I realized I was playing it way too safe.
The car is now a little insane. IDK if I was slipping the clutch or the tires in 4th at 73mph. 4.5psi peak boost. It drives a lot like my old 2004 Forester Turbo 5 speed with an 18g turbo and tune.
OC Fit Wit
11-02-2016 10:41 AM
AnlDyxp_GD3
28
08-22-2010 01:25 PM
1990hondahf
07-07-2009 12:25 PM
kenken
14
06-27-2009 09:54 PM
Zivman
15
09-22-2008 05:03 PM
Quick Reply: Hks turbo kit for 2007-2008 gd3
