Bumper protector
I use my Honda Fit for work unloading and loading a lot of things out of the trunk,I do have the legit scuff protector whatever you want to call it for the rear bumper but i use a good quality contact paper which is actually plastic with non-permanent adhesive. It sticks on there for a few months and then when it's time to replace it's starting to look a little grubby around the corners works great to protect the bumper and I've even installed a few squares on the driver rocker panel to prevent boots and what not leaving scrapes and things. I probably could have done a better job applying it and taking more time but it's not meant to be permanent anyhow only took maybe 10-15 minutes at the most and a big roll of it at Home Depot is less than $10 you can find the other regular quality rolls at Dollar Tree even and there's plenty for a few applications
