Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   Fit Interior & Exterior Illumination (https://www.fitfreak.net/forums/fit-interior-exterior-illumination/)
-   -   HELP! Radio and Dome Light doesn't work (https://www.fitfreak.net/forums/fit-interior-exterior-illumination/10467-help-radio-dome-light-doesnt-work.html)
heymikesays Dec 17, 2006 04:13 PM
Problem solved! Ahh thanks for looking anyway.
Guess I could show the map lights which caused the mess to begin with
http://i23.photobucket.com/albums/b3...100_0440-1.jpg
http://i23.photobucket.com/albums/b3...s/100_0444.jpg
spider2k Dec 17, 2006 07:26 PM
lawlz i have my broadway from my s2k in mine too.
sillypuddy Dec 17, 2006 07:33 PM
what car are those maps lights from?
-joe
heymikesays Dec 17, 2006 08:41 PM
-joe
2006-07 Honda Civic
Spule 4 Dec 17, 2006 08:54 PM
Any brackets, or just a hole in the headliner? Looks sharp!
heymikesays Dec 20, 2006 09:54 AM
so far it mounts without a bracket just fine. no looseness and/or movement when pushing the lights on. im debating whether or not fabricating a bracket is even necessary. I did use the factory foam to place in areas where the roof might give way if the unit is used and its pretty sturdy.
sorrikim Dec 27, 2006 11:49 PM
Hey! How was the wiring? was it easy to connect the wire? and where did you connect it to?
heymikesays Dec 28, 2006 02:00 AM
I hooked up the power to the red/white wire of the dome light, ground to rear view mirror (search other posts)
The unit itself im still trying to locate a wiring diagram as I am having difficulty getting the passenger side light to work (driver side works fine) Otherwise, it doesn't go off when the dome light does and one light works so im one light away from this being completed.
supremeXorio May 7, 2012 12:18 PM
What was wrong? My stereo ,map light and trunk light as well as my parking lights all don't work
Black3sr May 7, 2012 02:25 PM
Someone stole your battery.
supremeXorio May 8, 2012 12:41 AM
Ya some troll had it. All fixed now.
© 2026 MH Sub I, LLC dba Internet Brands
