Strange Lighe Idea !!!!!!!!!!
Old Jun 16, 2008 | 07:08 PM
kimo's Avatar
Exclamation Strange Lighe Idea !!!!!!!!!!
I have kind of strange idea, to change the blinker in the headlamp to a normal light bulb for better lighting, also was thinking to make it on when I turn on the parking light on, was thinking if could like install HID in it.
Old Jun 16, 2008 | 07:21 PM
cojaro's Avatar
Isn't already a normal bulb?
We have separate parking lights already.
It'd be silly/completely unnecessary to make the turn signal HID.
Old Jun 17, 2008 | 10:59 AM
kimo's Avatar
normal bulb, or change the yellow bulb to a clear one.
Originally Posted by bryanback
Unless you mean your standard A-Base Incandescent Bulb. . .
Old Jun 17, 2008 | 11:06 AM
kimo's Avatar
I want to make it HID not forthe signal but it will be on all the time, and cancel the front turn option.
Old Jun 17, 2008 | 12:59 PM
yeamans17's Avatar
That would be useless, the shape of the reflector in that housing would be horrible for HID, you'd have a lot of pissed off people coming the other direction. And why would you want to eliminate your turn signal? Its there for your safety as others.
Old Jun 17, 2008 | 01:13 PM
kimo's Avatar
It doesn't have to be HID. I changed the yellow bulb to a clear one, and I noticed that the light is kind of strong. I can use other bulb that will work as a turn signal and front beam.
leslieliang
Apr 2, 2014 06:43 PM
madtodaimax
Feb 26, 2014 04:22 PM
Turbo_Mouse
Feb 8, 2011 12:21 AM
cKranez
Aug 10, 2009 11:48 AM
kroze
May 28, 2009 11:27 PM
