HID's having problems turning on! Please help!!
I have had this Bi xenon hid kit installed in my car since 12/07 and everything was working fine until this week. Now its taking my at least ten times (on and off) to get it light up. Could you guys tell me if it's the ballast going bad or sometime is wrong with the wiring. This kit has a relay that you must hook up to both ballast. I've already sent the kit back to the seller once before for the same problem. I'm thinking of just buying a single hid kit so I got less parts that could break. Thanks
It's the ballast going bad..
so you're saying both ballasts are going bad? What hid set would you recommend. thanks
I would recommend OEM ballast quality is good but since you are on a kit you can try xenith HID kit most of the guy are using them and they seem to have no complaints
Originally Posted by bitoy
(Post 411541)
| All times are GMT -4. The time now is 08:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
