GE8 HID Installation
I recently received my H4 4300k Xenith Xenon HID headlight kit and would like recommendations on the best location for mounting the ballasts. I was under the impression that most HID kits can be installed without removing the front bumper for the GE's, and figured it would be a fairly straightforward DIY (which it probably is) but I would feel more confident knowing I have them mounted in a place which is known to work best.
The kit does come with some mounting gear for the ballasts, and a a few wire ties, but before I start bending and re-shaping everything I thought I would ask.... The drives side headlight has a great spot to mount it, but again I would have to bend the mounting gear and the ballast would just kind of hang down. Of course the same spot on the passenger side has the windshield washer fluid reservoir in this area so it's a bit more of a challenge. I have a few quick shots of these areas attached. I haven't contacted the vendor directly about installation, but in stead hope to start some ideas here to share with the group. What may help best is a shot or two of someone's own GE HID kit install, if available....Thanks! http://img111.imageshack.us/img111/9...gersidesy4.jpghttp://img228.imageshack.us/img228/3...gersidezp8.jpghttp://img155.imageshack.us/img155/7...tcenterzh4.jpghttp://img111.imageshack.us/img111/2...rsside3nv9.jpg |
on the passenger side..bolted it to the thing next to the water reservor on the left side if u facing the car....theres a spot to bolt it dwn to...too bad i dnt have a picture camera to show u
on the driver side i bolted it to some metal thing that was sticking out....dnt see it in ur pictures.... |
Please post pics after you are done reako I would really appreciate it. I'm going to be purchasing and installing the same kit on an '09 also.
Don't sweat over the best place to put the ballast.
Trust me I've installed HID kits on close to 100 vehicles including GE8. The best location for ballast is any place where there is not excessive heat, not close to timing belts or other wierd things and securely fastened or tightened, either with zip-tie or existing bolt. All aftermarket ballasts are made to be waterproof, impact resistant. NEVER drill your car chassis or put it in a place that takes you 5 hours to remove. That said, I think I finished installing a bi-xenon HID kit on a customer's car within 20mins. If it's taking you more than an hour, you are doing something wrong =P |
yeah...ge8 has plenty of room....if anything
double side tape it to the fender wall make sure u get the automotive double sided tape..those will hold good..even if water get onto it body side molding and door visor use the same double sided tape..so it wil stick =) just clean both surface well before applying tape |
Thanks guys for your input!! I will swing by auto zone tomorrow and find some automotive double sided tape, and will begin installing tomorrow morning.
let us know how it worked out!!!
Originally Posted by 713_fit
(Post 515945)
nice job
i think on the driver side is the same spot i bolted my hids to too!!! |
(Post 516903)
nice job
fog lights flickers or head lights or doesn't work ground the black wire off the ballast to the chassis the red wire to fog light stock wire. Did it to my fit the morning and test drive the fit in wet conditions and it works no problems with my hid fogs or head light hids
Originally Posted by viperjh16
(Post 517451)
its ok [IMG]file:///C:/Documents%20and%20Settings/master/My%20Documents/My%20Pictures/Picture/Picture%20009.jpg[/IMG]
plug
hey wasup dude, i just got my HID kits. i was wondering if you can get a closer picture of the HID plug that connects to the car harness? i am kinda lost at the moment since i havnt taken the time to unplug my headlights. thanks
pop off the bumper and u could see every thing it easy
My set died last week and I threw everything away. Sorry man.
Originally Posted by deluxrockz
(Post 885135)
maybe you shouldn't be doing this. |
some always with their stupid answers like GOOBERS, i wasnt even asking you for the info. so why ur replying like if my question bother you. [thanks for your help reako]
You may think it's stupid, and that's fine. But if you are unwilling to spend five minutes (or less) opening the hood and unplugging the bulb, but yet willing to wait potentially much longer sitting at your computer, what does that imply?
Why not unplug it now, get used to it, get a feel for your car that you are attempting to modify. But, hey, whatever floats your boat. Edit: here's somethingto chew on... You dug up a 17 month old thread, didn't get a response for 4 hours. And unfortunately, the OP no longer even has the setup in which to get the picture. When you could've spent the 5 minutes to open the hood, unplug the headlight bulb, pull it out, look at it and then put everything back together. |
