Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   Fit Interior & Exterior Illumination (https://www.fitfreak.net/forums/fit-interior-exterior-illumination/)
-   -   Question: Wiring my 09 Fit's interior LED lights a certain way (https://www.fitfreak.net/forums/fit-interior-exterior-illumination/49966-question-wiring-my-09-fits-interior-led-lights-certain-way.html)
toonie Oct 27, 2009 07:54 PM
Hello everyone! :wavey:
This is my first post, I just bought an 09 Fit and I'm very excited to light up the insides!
I learned a lot from the many threads about wiring interior lighting, but I'm still very new to this and I hope I can get some more tips so I don't do this wrong!
I want to set up some lighting in the foot-well area with a switch connected to it. What I would really like it to do is to have it connected to both the dome lights and the head lights. So no matter if the switch I have is ON or OFF, opening the door will always turn the LEDs on, but if the switch is ON, then the LEDs will stay on if my head lights are on.
I know it shouldn't be too hard to set up either of them (just a matter of finding the right place to connect the wires) but is it possible to link them together?
Any feedback and tips would be GREATLY appreciated! Thanks!
$2
Zalthras Oct 28, 2009 02:38 PM
That sounds a little bit like what I did (see link in my signature). Except, to tie it to the headlights you'll need to run the ground side of your switch to the red wire on the combination switch (pin 10 on the combo-switch connector or pin 5 on the 'M' connector on the back of the fuse panel).
© 2026 MH Sub I, LLC dba Internet Brands
