GD3 Daytime Running LED's (help?)
Sooo hello all, this is my first day as a member on these forums although I have been leeching as a visitor for the longest time. I just got around to installing some daytime LED's on the front bumper of my GD3, which are wired along the inside of the right fender, through a grommet in the firewall, and into a switch straight into a 30A fuse i inserted into an empty slot, (Not Used).
http://img16.imageshack.us/img16/7199/img0030ty.jpg http://img89.imageshack.us/img89/5019/img0037xbs.jpg They all work just fine, at first, and the switch controls them with no problems. But 3 of the bulbs in the right (car's right, not camera's) light, after a few minutes, just go out and it's the same ones every time. I have fumbled around with the wire, both inside the car and out, and nothing, and tried all these other fuse slots and the same thing happens...Any suggestions...? *And keep in mind, this is my first-ever post, let alone thread...There aren't that many DRL threads on here (at least that I've seen). HALP! Voltage, wrong fuse, wrong gauge wire...? Also, what do you think?:p |
crappy lights probably..
when i replaced my stock interior lights with leds they were great but burned up in 2 weeks bc i bought cheap ebay lights.. the second time around i spent some moolah and theyve been great since.. you get what you pay for |
Originally Posted by drock305
(Post 1016932)
| All times are GMT -4. The time now is 11:25 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
