Installing a rear dome light in the headliner
11 Attachment(s)
This is possibly the most useful add-on i have done yet. I got this little hatchback because i needed a car that was all-round cheap to own, and can support my lifestyle which involves having the rear seats folded flat at all times, using the cargo area. this means i use the rear trunk area intensely, and since i keep surfboards along the right side blocking the piss poor rear lighting, i am left in the dark when i need to access the many different things i keep back there. so i started searching the web for overhead dome lights that affix directly to the headliner, that also has a stock look to what you might see in the honda fit. alas, i found the dome light assembly of a 2011 hyundai accent, with a clip-in mount. And that is where this project begins...
start by making a template for the hole you will eventually cut into your headliner: https://www.fitfreak.net/forums/atta...ine=1444945308 https://www.fitfreak.net/forums/atta...ine=1444945308 second, prep the wiring so the dome light will work in the "off" and "door" position. the hot wire is the brownish wire, and the ground wire (which the door switch is connected to) is the white wire. I used red for my hot line, and white for ground. pop out the existing rear cargo light assembly exposing the wiring: https://www.fitfreak.net/forums/atta...ine=1444945308 make sure the wiring works correctly; the following photo shows the hot line in, and ground for the "door" position out. how you connect the wiring to the hyundai prongs is up to your creativity: https://www.fitfreak.net/forums/atta...ine=1444945308 If everything works at this point, go ahead and run the wiring up into the ceiling. all the plastic pulls off with clips, enough to run these wires. just ensure theyre long enough to run where you intend on placing the light. Following is the location i chose, where there is plenty of room between the headliner and metal to fit the light. it's the driver side forward of the latch system recovery point. you might be able to go dead center in front of the of the latch system connection, but it is risky because of the antenna. where i placed it was the safe bet: https://www.fitfreak.net/forums/atta...ine=1444945308 use a sharp utility blade to cut the hole: https://www.fitfreak.net/forums/atta...ine=1444945308 there is plastic that also has to be cut out... not too hard though: https://www.fitfreak.net/forums/atta...ine=1444945308 https://www.fitfreak.net/forums/atta...ine=1444945308 now, run the wires out through the hole, and make sure everything works. the may need to close and open the hatch because the door switch in the hatch is on a time and with shut off even if its correctly connected: https://www.fitfreak.net/forums/atta...ine=1444945308 this is a good time to make fine adjustments to the hole you made so the light makes a snug fit. now you gotta run the ground for the always "on" position. it's the only left over prong on the light assembly left. i connected the ground to the antenna up inside, above the headliner: https://www.fitfreak.net/forums/atta...ine=1444945308 now just make sure all the wiring is connected, pop the light in, and you got yourself an awesome, stock-looking, FUNCTIONAL, dome light. https://www.fitfreak.net/forums/atta...ine=1444945308 Ive had the light in for a few days now and it blows my mind i went this long without quality lighting back there. i strongly recommend this addition. |
Looks great, I've been thinking on installing a dome light on the front since the Base only comes with one on the roof and it is not that bright/useful. Could you please share the part number for this ?
No flames meant - not trying to dis your work - just offering other approaches.
One of the folks here swapped out the rear cargo light with the Acura Cargo Light w/switch 34265-SFE-003. Its apparently a drop in upgrade - he said it took him about 2 minutes total- so now he can manually turn off the light on or off when the hatch is open. Link to his thread - https://www.fitfreak.net/forums/fit-...ll-w-pics.html From the picture it looked similar in function to the front done lights in my 2012 Fit sport - push click for on, push click for off. Other folks have articles on swapping in LEDs to make it brighter |
Originally Posted by thewebgal
(Post 1325502)
Originally Posted by cajlog
(Post 1325501)
(Post 1325501)
(Post 1325527)
i don't think the switchable light was his goal. even with that upgrade its really not that bright. the side light doesnt cover the whole hatch. other solution was to do something similar but wire a separate light at the other side. i may do this myself.
