Independent Foglight Mod not working anymore?
Old 01-01-2017, 03:16 PM
PUPPETSLAYER's Avatar
Hi FITFREAKS.
Fog mod went Ok, but suddenly its not working anymore. Checked everything (fuse, cables, switch, relay, mods, etc) and everything is Ok. What happened? Have this happened to you guys? What to check now? Thanks FitFreaks ��
Old 01-01-2017, 06:30 PM
Forget it FitFreaks, found a wire loose. Sorry. Thanks ��
Old 04-09-2019, 07:26 PM
how did you make the fogs independent? ive been looking all over for a how to
Old 04-10-2019, 12:16 PM
JohnpaulX's Avatar
It is in the sticky section: https://www.fitfreak.net/forums/fit-...as-answer.html
Long story short, trick the relay to have power always instead of only when the low-beams are on. In the case of aftermarket lights, you can do this by taping the 12 V battery where it says to tap the low beams.
Old 04-11-2019, 10:59 PM
thats for the gd3 tho right? i gotta ge8 lol
Old 04-12-2019, 12:12 AM
And I have a GK and still made this work for me.
Old 04-15-2019, 01:11 AM
so all the fog light wiring is the same? through out all the years?
Old 04-15-2019, 01:40 AM
so heres the light switch connector. theres no red and yellow wire just one red one. is that the wire i need to cut? i cant see any pics on this post btw
NRG
09-27-2016 09:44 PM
wavedivision
03-15-2014 12:57 PM
sandblasted
19
04-16-2012 04:48 AM
Evan_2k
12-13-2008 05:49 AM
xonexlifex
07-15-2008 08:45 PM
Quick Reply: Independent Foglight Mod not working anymore?
