Honda Fit - Poor Headlights according to IIHS
Old Nov 12, 2018 | 01:17 PM
  #121
2Rismo2's Avatar
My 2004 4Runner has better headlights than my 2015 Honda Fit...
Once these PIAAs burn out, I'll be sourcing an LED upgrade.
Old Nov 12, 2018 | 04:17 PM
  #122
Uncle Gary's Avatar
Originally Posted by kenchan
keep us posted cause i dont mind trying LED bulbs if they last longer than 11months.
the funny is my wife didnt even notice the driver side bulb was burnt out until my son told her. and this was at night! so you can tell how bad the GK's headlights are..
Will do. Keep in mind the LEDs are also serving as DRLs, so they’re “always on.”
Old Nov 13, 2018 | 12:12 AM
  #123
Action Jackson's Avatar
sounds great. which bulbs are u running? i dont want to spend a fortune on this car as my GK is already half dead (one foot already in coffin)
Well I spent a relative small fortune on these. They were well worth it.
https://www.fitfreak.net/forums/3rd-...ml#post1384450
Old Nov 13, 2018 | 11:29 AM
  #124
CyclingFit's Avatar
I am a self proclaimed professional at driving with some of the lousiest headlights ever placed on a vehicle... The Jeep Cherokee is what defines the lowest achievable standard and is still called headlamps. They may as well be oil lamps from a horse carriage.... But anyways..... Thank goodness the Fit came into my life.
Has anyone ever checked the voltage getting to the headlight sockets? I may attempt to this on my lunch break. The Jeep Cherokee is plagued with undersized wire and poor grounding. I am fairly confident that most test reveal only 9-10 volts making it to the bulb. All this headlamp talk makes me wonder about the Fit and how common it may be for other vehicles to suffer from the same issue.
Old Nov 13, 2018 | 11:37 AM
  #125
wasserball's Avatar
Cheapest upgrade: Lights Sylvania Silverstar ULTRA 9003/H4 Pair $26.49 for Honda Fit in eBay. Installed 2/18/18. Performance still OK so far.
My biggest problem with replacing the bulbs is the removing and attaching the spring loaded holding clips in a blinded location.
Old Nov 13, 2018 | 12:17 PM
  #126
CyclingFit's Avatar
Originally Posted by CyclingFit
Has anyone ever checked the voltage getting to the headlight socket....
Just checked at 14.22v with the car running. This is a 2018 EX CVT. So voltage drop at the socket is not apparent.
Old Nov 14, 2018 | 02:01 PM
  #127
Thanks.. thought our bulbs were 9003 not H4? amazon shows $180 for the pair? that’s like the psychological value of my entire GK to me. lol. any cheaper LED’s under $50?
Old Nov 15, 2018 | 10:01 PM
  #128
nomenclator's Avatar
Originally Posted by woof
They have started to put LEDs on to the North American Fit - the 2018 has LED brake lights along with some other lessor things so I'd guess cost is no longer a real barrier. To go to LED headlights they'll probably need a new design headlight lens and electrical changes so I'm guessing we really won't see anything until the next major Fit redesign. There's the possibility of seeing adaptive headlights since the IIHS has been looking at that and seems to like the opportunity to reduce crashes and save lives.
Some of the Fit or Jazz models in countries other than the US seem to be available with some kind of projector beam headlights, I think LEDs.
Old Nov 15, 2018 | 10:05 PM
  #129
Seems like 9003 and H4 are 2 different specifications from 2 different organizations. Bulbs that meet one spec are almost always going to meet the other spec, and typically bulbs are designated with both numbers, that is, the bulb that is designated 9003 in one country is exactly the same bulb that is designated H4 in another country. Package labeling will typically list both names. There is also an HB[n] designation for the same bulb. I think its HB3 but I could be wrong.
Old Nov 15, 2018 | 11:08 PM
  #130
ahhh, that makes sense. thanks. havent been around halogens in a while forgot about all the different standards and which ones were identical/interchangeable.
but 180 for LED's for a GK? no thanks.
Old Nov 19, 2018 | 08:04 AM
  #131
stephenmarklay's Avatar
Originally Posted by bach
Yeah the fogs have turned out to be maybe the best part of the EX upgrade; it was a pleasant surprise when I realized how well they illuminate beyond the corners.
This is probably the reason I have never through too much about the lights. My fogs are on 100% of the time and that must be helping a bit.
Old Nov 19, 2018 | 10:14 PM
  #132
Uncle Gary's Avatar
H-4 was the original spec as released in Europe and used in the US in motorcycles. When the DOT considered allowing them in automobiles, they decided the tolerance for filament location needed to be tightened. The new spec was called 9003. Today nearly all bulbs are manufactured to the same spec and H4 and 9003 are used interchangeably.
Old Nov 20, 2018 | 10:46 AM
  #133
cgs2000's Avatar
I did install brighter bulbs with some improvement, but can I also install foglights to make near-vision better.
Old Nov 20, 2018 | 11:26 AM
  #134
Chitown Fit's Avatar
Post Silverstars Love Them Or Hate Them.
Some like them other hate them. I'm going to try the Silverstars when my stock lights go out.
Old Nov 20, 2018 | 11:29 AM
  #135
GAFIT's Avatar
I've bought them a couple of times. Strangely, they seemed to be a noticeable improvement when I bought my first set back around 2004.
The set I bought for our Fit a few years ago were ZERO better than cheap halogens as far as light output. Maybe even less lumens. Just slightly less yellow.
Old Nov 20, 2018 | 06:51 PM
  #136
cool, that makes sense.
arent those the ones that burnt out on my GK just a few wks ago (11 month life)? why buy such crappy bulbs when people are saying they burn out prematurely. as GAFIT noted it's not much brighter than stock, maybe a little whiter hue at best. my wife is okay with the factory halogens i put back on the car for now.. she only drives around well lit streets so.
Old Nov 29, 2018 | 08:07 PM
  #137
Shutterspeed's Avatar
I found the headlight situation got much better after we lowered my girlfriends fit. Its like the headlights actually cast on the ground in front the car. Which leads me to believe the lights might be aligned improperly from factory.
Old Nov 29, 2018 | 10:23 PM
  #138
did you use the tanabe with boat look? then maybe. the aim was set too low on my GK. i aimed it up a little bit and helped a little.
so been running the factory halogens and while it's the ugly halogen brown/orange hue, it has BETTER illumination vs that phillips bulb i was running earlier. unless youre going LED, id stick with stock.
Old Dec 3, 2018 | 07:59 PM
  #139
No I used H&R springs for the GE8
Old Dec 18, 2018 | 10:41 PM
  #140
CodemanGK5's Avatar
DIY Mini H1 projector retrofit was one of the first and best mods I've done to my GK. Well worth the time and effort!
