Refreseh Mode question
I tried to make Refresh Mode with my Fit, but I was not able
to recline it completely. Does it supposed to be hard to push down to make it completely joined between the front seat and the back seat? http://www.chadmin.org/solkim/vividb...Photo-0131.jpg I pulled the pessenger seat all the way to the front and I have this much space between the passenger seat and the compartment box. Is this proper space to make it Refresh Mode? http://www.chadmin.org/solkim/vividb...Photo-0128.jpg Someone please help~~ |
You need to recline the back seat as far as it will go, which is just an inch or two -- pull the back seat release handle and push back on the top.
Can you slide back the back seat? I never knew that.
Do I use the clip on the top of the back seat? |
Flip the lever on the top of the back seat and it will recline a couple of inches. When this happens, it moves the bottom of the seat, too. Then you can put it in Refresh Mode.
Once you've done it, you'll say, "DUH!" LOL!! |
WOW! How easy! LOL Thank you!!
