Audio Set-up & Radio Panel Replaced
Hi there! Here some photos of my newly installed radio panel, this is temporary Im planning to install a double din head unit. I have two switch in the bottom of head unit, the use of this is to switch on & off the two Power amp so that you can listen to a normal default speaker.
http://profile.imageshack.us/user/franceska7/ |
Here's All The Photos!!!Im Planning to upgrade all of this.
[IMG]http://img154.imageshack.us/my.php?image=p2280024je9.jpg] http://img154.imageshack.us/my.php?i...0026dl6.th.jpg[/URL][/IMG] http://http://img371.imageshack.us/m...0027bz5.th.jpg[/URL][/IMG] http://img154.imageshack.us/my.php?i...0028ew7.th.jpg[/URL][/IMG] http://img371.imageshack.us/my.php?i...0063hc3.th.jpg[/URL][/IMG] http://img371.imageshack.us/my.php?i...0065tp2.th.jpg[/URL][/IMG] My power Amp is Fusion Fjl-811d mono amp and Fusion FE-402 Two Channel. 5 Farad Cap . Infinity Kappa Series 12VQ for my Subwoofer, I had a Hifonics Goliath 2400 RMS Watts Sub but I need additional Fjl-811D amp to link to power-up the Hifonics Sub. and I need an Optima Battery. |
hey new guy here and alos from the UK,
Just wondered where you got the replacement panel from... and as i'm a total newbie, inside the audio compartment, is it double din or single? I got a motorised sat nav/dvd unit double dit and not sure whether it will fit or not? |
Honda Radio panel
I got my in Honda Chiswick in London Its about 56pounds. I dont have the part number because Im in the oilrig now. I'll be home on saturday. I will send to you the part code OK. Its a double DIN kit includes all the brackets. Is your radio panel is having a manual airconditioning? If you live in Glasgow i can order one for you and I can help you to fit it during my off. If you need more help my email is noeldsison@hotmail.com...tanx!
Hello,
thanks for the tip, plus i've pm'ed you :) |
