1st gen brake line replacement specs? help request
Old May 13, 2025 | 08:52 AM
fitcar07's Avatar
EDIT/UPDATE: If anyone knows another source to get lines already set up w/ the right connectors, etc for the 2007, or have personal experience using a kit for a later year on the 07-08, that would also be helpful.
ORIGINAL POST:
Hey folks. I'm planning to upgrade the brake lines on my 2007 fit to braided stainless steel.
I need the following info to make sure I get the right kit/supplies from Wilwood that will fit stock calipers:
Line Length:
Inlet Fitting:
Outlet Fitting:
Chassis Fitting Size:
Does anybody have a reliable source for this info you can point to?
I don't have the car right now and although I think I know what some of these are based on memory/a quick look a few months ago, I want to be 100% sure before I order.
I checked the online service manual and I've been poking around old threads here and on reddit and haven't been able to find this so far.
I'm hoping there's an easy resource I'm missing that somebody doesn't mind pointing me to. Thanks in advance!
EricFit
Jun 10, 2022 12:44 PM
ricochang
Dec 30, 2021 04:50 PM
GRF
Oct 20, 2021 12:32 PM
Watermellonfelon
Feb 6, 2020 01:17 AM
So it is
Dec 22, 2018 11:34 PM
