????? Skunk2 universal coilovers ?????
has anyone used the skunk2 universal adjustable springs on their GD FIT im looking for a DIY or some guidance on putting these on myself
http://www.boombopracing.com/ebay/pi...17-05-0740.jpg |
Want some guidance? Stop making multiple threads on this :mad:
just get skunk2 lowering springs or skunk2 pro-c coilovers.
1 thread would have done justice.. not 3 :rolleyes:
Originally Posted by keepitpg
(Post 665203)
they go on the same way you would install a lowering spring. are these sleeves going on a GD or GE?? the GE is a little more involved, all the weather cowling would need to be removed to access the front shocks. there are DIY guides all over this website that document a step-by-step install for both generations of the Fit.
i helped a friend install ground control sleeves on his GE and it can go as low as the pro-c's on my GD. looks so damn sexy :D MOST IMPORTANTLY, support the hub BEFORE you remove the shock for the front suspension. we put a jack beneath the hub and also supported it with a wire coat hangar incase someone knocks over the jack. i've been lucky and have never had to deal an axle pop-out. good luck! |
Since when has Skunk 2 made coilovers for the Honda Fit?
