preview - only if you like coilovers
Old Dec 17, 2009 | 09:24 PM
kennef's Avatar
i love suspension. here's a preview of a little something i'll setting up on the fit, on account of andy at amr engineering.
Old Dec 17, 2009 | 09:25 PM
kennef's Avatar
AMR Civic Strut
I took a look at a McPherson Strut at the request of Andrew Rayes.
Latter I found out Mr. Rayes is actually the manufacturer of struts and shocks.
His web sight is found at:
http://www.amrengineering.com/index.html
(They have an AW11 set as well)
The unit Andy sent me to look at was as raced on his personal car.
It is a mono-tube all threaded steel body. Take-apart design with a 9 position rebound adjuster.
This particular version tested has an inline separating piston. Dividing the Nitrogen charge from the damping fluid. (This is my personal favorite if package length allows it)
It has a 44 mm internal bore size (same as Ohlins)
And uses a steel piston with an O-ring backed (bore) sealing band. Just like the big guys Penske and Ohlins.
The working piston resembles an Ohlins. And use Deflected disk technology.
Leading to easy tuning and calibration by the owner (if he has the skills and tools required).
The shims are metric sizes with a 12mm center hole. Look like they could interchange with Bilstein or Ohlins. This unit was assembled using lock-tight and did require a small amount of heat from a propane torch to disassemble. But this practice is quite common in the shock industry.
As no manufacture want to be responsible for strut parts under high pressure accidently becoming loose. Or having an inexperienced user try to service the unit incorrectly.
And have it release its contents in your face.
Do not take this lightly_without training and proper tools. Do not attempt to service or tune a gas shock!
The quality and workmanship of the working shaft and shock body bore seem quite good.
And appear to be a good value.
The shaft seal it self is one I have not seen before. And has a bit more seal force drag than the high end players. But it appears to be of long lasting material. And does not exhibit the low shaft speed sticktition problems I have found in other struts in this price range.
The adjuster is quite effective. And covers a large range with nice linear steps between positions.
Andrew Rayes appears to be a hands on owner. Who is not only a club racer. But is headquartered here in the USA. And is personally committed to his products and service.
You will not find this in the shock world today!
The shock was easy to work with. And is of good quality.
Add to this service and sales in the USA.
My feeling at this time. This unit will be a hard one to beat!
And I can not wait to take a look at the AMR Struts for the AW11
Submitted by Alex Szilagyi
http://forums.evolutionm.net/northwe...-tracks-2.html
Itrader EvoX
EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old Dec 17, 2009 | 09:30 PM
kennef's Avatar
-hyperco springs
-made to order, so there is no off-the-shelf solution.
-amr sets are in use by evo guys in rally conditions.
Old Dec 20, 2009 | 08:23 PM
wdb's Avatar
wdb
Very nice looking. I'll be interested to see a set on a Fit!
Old Dec 20, 2009 | 08:40 PM
SPON FIT's Avatar
call me crazy but didn't a thread pop u a while ago about amr coilovers that didn't end too well
Old Dec 20, 2009 | 08:50 PM
kennef's Avatar
post it up. AMR is new, so it's not impossible. BUT considering the success AMR equipped cars have had in some pretty heavy use, it wouldn't be consistent.
Old Dec 22, 2009 | 06:24 PM
kennef's Avatar
read this as posted by fitfreak.net moderators- the long story short is that there was someone claiming to be andy@amr.
i am still looking to support amr considering how well their hardware has held up on evos in rally. evos are fairly heavy and rally will definitely break your shit if you run junk such as megans, teins, killer bee, and some of the other bullshit that passes for suspension.
https://www.fitfreak.net/forums/fit-...ment-read.html
Old Dec 22, 2009 | 06:28 PM
Gbaby2089's Avatar
until now i've never heard anyone call Tein junk
Old Dec 22, 2009 | 06:32 PM
kennef's Avatar
it's like the matrix - welcome to reality. and i don't say that to insult anyone. nothing personal at all but if someone is going to spend money on coilovers, please don't get tein.
Old Dec 22, 2009 | 06:35 PM
Gbaby2089's Avatar
please enlighten me on this.....I've always heard that Tein = the third best production coil-over available behind JIC Magic and KW
Old Dec 22, 2009 | 06:37 PM
JDMxGE8's Avatar
You should tell Loi Song to take off the TEIN SRC coilovers off his record-breaking time attack Civic Hatch then. It's all good to promote AMR Engineering, but don't go bashing on companies that actually make good products.
Old Dec 22, 2009 | 06:51 PM
kennef's Avatar
when it comes to suspension, JIC also does not rate. not as bad as tein et al but still not worth your money. JIC is rebuild city, for those that can tell they need a rebuild.
KW has enjoyed success in the very serious motorsports arena, though they don't have the same name-dropping recognition as JRZ, Ohlins, Moton here in the states. ultimately, if you want coilovers for something other than dropping your car onto its bumpstops, off-the-shelf solutions from KW are pretty poor, evident in their spring rate selection. with that said, you can get a set of "custom" valved and sprung KWs that are fantastic, though pricey.
Old Dec 22, 2009 | 06:53 PM
kennef's Avatar
i'm not sponsored, i pay my own bills, like most people here. do you now Loi Song personally? and would you tell me what records he's breaking?
so, understand that i support AMR by choice, not because of incentive. my opinions are my own based on my experience, some of which is first hand and some of which is because i learn from others, and should not be seen to speak for andy@amr (the real one) or anyone else that i choose to support (swift springs, the guys that make the rsb on my wife's fit, KW when i used to have a set of their clubsports, etc). such is the power of networking and the internet.
Gbaby2089's Avatar
well can't you get a set of custom valved and sprung c/o's from JIC and Tein as well
I've always heard that the JIC FLT-TAR are #1 for my platform (8g galant/3g eclipse) KW V2, then Tein SS-P
Old Dec 22, 2009 | 07:03 PM
kennef's Avatar
given time, money, and national exposure - certainly. JIC FLT-TAR customized by mueller for the evo platform has shown to require frequent rebuilds and be slower than similarly priced custom KW sets. tein can be customized i'd bet, but for that money i would ask whether stepping up to a motorsports based suspension program might be more worth my while.
side note not related to coilovers - how many folks have complained about blown dampers on tein springs? not just in the fit community, but across platforms? it's just hard to take "dress up" springs seriously, sorry.
Old Dec 22, 2009 | 07:05 PM
Gbaby2089's Avatar
i'm on tein springs and my shocks are fine 15k miles on em so far
although if i blow my shocks/struts i don't care these are just holding me until I get coil-overs
Old Dec 22, 2009 | 07:08 PM
JDMxGE8's Avatar
I don't even know why you're bringing JRZ, Ohlins, and Moton into this mix. They are in a different class from KW and JIC Magic, and AMR Engineering.
I pay my own bills too. No, I don't know Loi Song personally. Did I say that I did? I was using him as an example. His Civic, piloted by Tim Quo, clocked a blistering 1:55.948 at Buttonwillow CW.
Old Dec 22, 2009 | 07:20 PM
dewthedew's Avatar
oh god not this again....... :facepalm:
Old Dec 22, 2009 | 07:23 PM
kennef's Avatar
point being that i would verify first that teins, built and custom valved by the engineers at tein, using tein parts and not just a green shock body with the real meat and potatoes made by someone else, were equipped on that car. if you have credible validation of that, then good for tein. tein does not have a good rep; the onus is on them to prove that they know what they are doing, as far as i'm concerned.
i'll just say this - it wouldn't be the first time that the stickers on a successful car don't match the equipment on the car. take it or leave it, i'm not going to get any further into it than that.
Old Dec 22, 2009 | 07:34 PM
JDMxGE8's Avatar
I'm done too. Sorry for thread jacking.
