Skunk2 Springs + T1R S-Spec Dampers
Old Feb 18, 2010 | 10:39 PM
3906brad's Avatar
I used to run factory dampers wit the Skunk2's, but I got my S-Specs in the other day, got them installed today.
First thing I noticed was the back coils compress so much, they have like 4 links touching each other. (I can get pics tomorrow). Also, the back suspension, when driving, creaks really bad, pretty much sounds like the coils rubbing against each other.
Anyways, my question is this: Do any of you run this set-up and had the same issues? If so, how was it resolved? Anyone else run these dampers with other after market springs and get the same issue? How was it resolved?
Thanks
Old Feb 19, 2010 | 12:32 PM
3906brad's Avatar
Got the problem resolved. One of he rear springs wasnt seated properly. Thanks for all of your replies!! =D
Old Feb 19, 2010 | 12:37 PM
dela's Avatar
review on the combination?
Old Feb 19, 2010 | 02:07 PM
3906brad's Avatar
Getting alignment now and tires installed in the next few hours or tomorrow. I will give a proper review then.
Old Feb 19, 2010 | 02:42 PM
GD3_Wagoon's Avatar
nice. i have s-techs that need to be installed as well. can't wait to read your review
Old Feb 21, 2010 | 12:54 PM
3906brad's Avatar
My past set-up was Factory Dampers with the Skunk2's. The passenger side rubbed a decent amount at first, but from the 2 years it was lowered, everything that could rub, has rubbed, so hardly any rubbing before the change. Now that I have changed, getting a decent amount on the driver side, but I am sure it will eventually do much like the passenger side did.
The tops of the S-Specs has the adjuster. 14 clicks- Softest to hardest ride. Pretty much, the way it keeps track of the clicks is the fact that its a type of 'ratcheting' set-up. This small piece can be removed and replaced, if need be. Well, one of my struts came with a bad ratcheting system on the adjuster. I can still adjust the strut, but there are no 'clicks', so I have to guess where it is adjusted to.
I bought my struts through vexmotorsports.com. They told me to contact T1R. When i did, they referred me back to vexmotorsports. Then Vex sent me to (surprise surprise) AJ-Racing. Now I am dealing with them, but they dont seem to understand what the **** I am talking about.
I DONT NEED A NEW STRUT!! I need the small ratcheting adjuster part on the top!!
So until I get my struts all properly tuned, I dont really want to write a review (even though it is much better than what I had).
Lightarrow
May 3, 2012 02:36 PM
ruelthewOrld
Mar 2, 2010 09:25 PM
JCrimson
Jul 24, 2009 09:26 AM
Tofuik
Oct 27, 2008 12:25 PM
FITGD3
Apr 18, 2008 10:57 PM
