SPC camber bolts with oval suspension holes!! YES IT F N WORKS!
Im using skunk2 pro c coil-overs. I also have spc camber bolts. With out maxing out the combination of the camber for the front, on accident while trying to achieve -2.5 front, My camber went to -3.2
Yes, it can go more. The alignment dood said probably -4 degrees!!!!!
I told him to set it to -2.5 so that's what its at now with the spc bolts and the adjust ability my pro C's offer.
Just wanted to add this to the forum knowledge base cause NO one has answered this and Everyone has asked.
I also DO know skunk2 says not to use the bolts with their oval holes. F it. Ive been doing it for 7 months now on the road course and daily drive. its fine. I just now wanted more front camber and unleashed the power to reveal its true abilities.
You're welcome.
You're welcome.
Just to add another confirm to what JCrimson said, I've been running camber bolts on KW V2's (has an oval hole) for a year and a bit now, daily driving and a few times on a road course. Alignment is still fine for me. When I went for the alignment after install, the shop told me the max they could do on my car was 3.7 deg on one side and 3.5 deg on the other.
whitefitsport
Oct 2, 2018 10:54 PM
ciref8
Oct 17, 2014 12:31 AM
FELIXY69
Jul 21, 2009 10:38 AM
