DIY: Koni Yellows for GD3 rear
Old Sep 16, 2012 | 09:15 AM
  #61
apexanimal's Avatar
i don't want this thread to die...
Old Sep 16, 2012 | 10:28 AM
  #62
If anyone is not a fan of Koni and would rather use Bilstein.
Bilstein makes a shock from their SPORT line for the 1999-2001 Saab 9-3. The valving is likely different but as far as making it fit, its exactly the same as the 900.
I've heard that the Sport blows the Yellow away in all regards, oh and its about 1/2 the price.
Old Sep 17, 2012 | 09:33 AM
  #63
apexanimal's Avatar
is the bilstein sport adjustable like the yellows? the p/n is 24-027588?
where are we with the front struts?
Old Sep 17, 2012 | 09:58 AM
  #64
ragingti's Avatar
The Bilstein Sports are not adjustable, while they are good, I would say not as good as an adjustable Koni yellow.
Old Jan 19, 2013 | 08:04 PM
  #65
appleica's Avatar
does anyone have a picture of their car with this installed? I have a full set of coilovers with the rear damper just giving out lately.
I want to replace it with the koni and be done with it.
Old Jan 19, 2013 | 08:48 PM
  #66
mike410's Avatar
Yeah, if you need any others let me know. I'll look to see what I have or take some new ones
Old Jan 19, 2013 | 09:32 PM
  #67
appleica's Avatar
wow that's awesome so you can go that low. Are you on the bump stops?
side note, what kind of wind visors are those?
Old Jan 19, 2013 | 09:38 PM
  #68
appleica's Avatar
mike410> wait a min, is that your car with the koni's or your air bag system? that's way too low to drive normally...?
Old Jan 20, 2013 | 01:21 AM
  #69
mike410's Avatar
JDM Honda Access visors.
Don't think im on the bump stops as the tire is sitting on the wheel well. Koni shocks on the rear with the airsprings. Pretty much the same as a traditional setup, I can just adjust the height with air pressure.
Looks like this but now has the Konis
Old Jan 27, 2013 | 12:03 PM
  #70
Blue-Civic-Hybrid's Avatar
Question Koni front struts?
Was a solution ever found for the front struts from Koni? From what I have read from the thread, nothing yet.
Thanks for doing the research on the rear Koni shocks, that will definitely help when I replace my 100k mile OEM shocks this summer.
Old Mar 19, 2013 | 01:46 AM
  #71
THE_CRUCK's Avatar
Mitsubishi mirage oem struts are same inner and outer diameter but about 5-6 inches shorter. Need little modification. Best for air suspension as depending on your lift should be about 7 inches. I just used my factory front struts. Cut the lower spring pocket off leaving the weld to support the bottom of the bag from pushing down. Soon I'll be doing the mirage struts to get lower. Right now my rear trailing arms hit the frame and the front is about .5 to .75 higher. i plan to have it laying pan soon. Won't take much. Hope some of this helps.
Old Apr 17, 2013 | 02:05 AM
  #72
Bump for any updates..
Old Apr 29, 2013 | 09:15 AM
  #73
Honda_chemist's Avatar
If you scroll down a few posts to custom Koni coilovers, I managed to use their universal single adjustable 8610 1436 race inserts for the front. I had bunk-over-sprung coilovers with a 50mm OD full-body threaded damper cartridge. Discontinued diameter BTW, with our wee lower brackets and fat americans.
Rather than the ground control sleeve-over style system; I hollowed out the damper and used the housing as my own sleeve-in system. Worked great and is DESIGNED for MacPherson style strut units.
The new dampers in coilover units offered for the FIT appear to be going 53mm OD which gives us the opportunity to mate the larger 45.5mm diameter konis inserts.
Old Apr 29, 2013 | 12:04 PM
  #74
solbrothers's Avatar
Mike I love you yazz
Old Apr 29, 2013 | 12:26 PM
  #75
gimme's Avatar
Master FitFreaker
stickied...
Old Apr 29, 2013 | 02:08 PM
  #76
TPColgett's Avatar
Which coil overs did you convert and re sleeve?
If it's not crazy challenging... I might do the same with single adjusts to my Skunk2 Pro C's....
Old Apr 30, 2013 | 11:30 PM
  #77
Technically not the thread.....
Old Aug 18, 2015 | 09:38 PM
  #78
der Mond's Avatar
Thanks!
With the yellows on the rear and the Progress bar and 32 psi front / 25 rear the car is finally, to quote Goldilocks, "just right."
Old Aug 18, 2015 | 11:05 PM
  #79
MySlowFit's Avatar
koni ftw. nice setup
Old May 2, 2016 | 06:22 PM
  #80
Kurse's Avatar
So? Anyone found something for the front?
I'm confused now..
