Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   Fit Suspension & Brake Modifications (https://www.fitfreak.net/forums/fit-suspension-brake-modifications/)
-   -   Skunk 2 Pro C's super stiff (https://www.fitfreak.net/forums/fit-suspension-brake-modifications/79832-skunk-2-pro-cs-super-stiff.html)
gnarlyj3rick Oct 2, 2013 11:46 PM
So i managed to get the rears slammered by taking out the perch and both rings so it's just the spring sitting in there. The shocks are screwed down all the way so that there's about an inch of threading left. But it's SUPER BOUNCY.
Question is, how should the shocks be adjusted for shock travel? Thinking the car is riding on the bumpstops.. I'm guessing these weren't designed to be riding on the spring themselves..
solbrothers Oct 3, 2013 12:05 AM
raise it back up
dewthedew Oct 3, 2013 08:45 AM
you answered your own question lol
13fit Oct 3, 2013 01:26 PM
only way to remove bounce without replacing is to take off the rear shocks, go to a machine shop, and have them step down the threads about 2-3 inches. This will pull the rod back out to its designed area, and still allow you to run your lowering springs
eddiec168 Nov 20, 2013 03:04 PM
I think the shocks aren't damping enough. I feel like the springs are stronger than the shocks.
© 2026 MH Sub I, LLC dba Internet Brands
