rear disc finally
after years of searching and looking
it finally came in got it from Japan Yahoo auction comes with ebrake cables, brake lines and ABS sensors can't wait to put it on :) http://img155.imagevenue.com/loc72/t...o_122_72lo.jpg http://img101.imagevenue.com/loc66/t...o_122_66lo.jpg http://img148.imagevenue.com/loc172/..._122_172lo.jpg |
jealous...
Looking forward to seeing them on the car Alic. :D
Originally Posted by gawa
(Post 1216789)
Nice! Are you just going to completely swap rear axles or transfer parts over?
The reason I ask is due to wanting to do an OEM like rear disc conversion on mine. My current dilemma is finding out what spindles, calipers, and caliper brackets will work together. EDIT: I think the rear calipers are the same as the USDM '99 Civic SI and Integra GSR. Can you post up a picture of the code stamped on the rear calipers please? ^.^ |
Originally Posted by Hootie
(Post 1217024)
The reason I ask is due to wanting to do an OEM like rear disc conversion on mine. My current dilemma is finding out what spindles, calipers, and caliper brackets will work together. EDIT: I think the rear calipers are the same as the USDM '99 Civic SI and Integra GSR. Can you post up a picture of the code stamped on the rear calipers please? ^.^ the caliper brackets is the same as they use the same pads, the caliper itself is not the same cause I believe Civic brake lines goes in from the bottom or side and not the top, but if u use braided lines then it doesn't really matter this whole beam only costs $150 but shipping over from Japan is a different story lol |
great to have rear disc brakes, but the CRZ setup bolts in no problems. matching brake hoses and e brake cables are all you need, for future peeps
Originally Posted by ccFit
(Post 1217026)
yes swap the whole thing would be much easier only 4 bolts
Originally Posted by 13fit
(Post 1217031)
i will get you some pics
I have no idea CRZ has the same setup |
insight, crz, and fit share chassis base.
For gasmileage queens, insight front control arms and using insight rear drums, shoes, and hardware leads to over 10 pounds of unsprung weight loss. CRZ front control arms and knuckles, and rear axle assembly, makes the fit enjoy 5x114.3 and disc all around. Im not sure of weight difference, though I think we can all riightly assume unsprung weight increases |
(Post 1217042)
If memory serves me right, you'll only have to go 5 lug only if you use the CR-Z's hub and rotor. I'm still researching this but it seems like you'll likely have to run EP3 SI rear discs (and possibly additional/miscellaneous hardware) since they are the same diameter as the CR-Z (10.2 inches) but I'm not sure of the hub bore or spacing to be honest.
Will the CRZ/Insight stuff work on a GD3 as well?
it does look like there is an adapter plate that bolts up to the beam that u can order from Honda, now sure if it will bolt on to the beam with drum
i will get some pics for your guys tmr when I am back at the shop |
(Post 1217024)
Originally Posted by 2poler
(Post 1217068)
Originally Posted by FitStir
(Post 1217189)
If you go thru the old T1R GD3 rear conversion threads and/or the Type R (Jodele's thread) front brake upgrade thread the information is in there about which OEM Honda parts will work for a GD3 upgrade... iirc, you can get all of them in the US. (but double check though)
http://www.aj-racing.com/ajpwr/Fit/T1R-spindle.jpg I do have an idea though... :nod:
(Post 1217189)
Good question, the OP has a GD... I don't think CRZ/Insight fitment has been confirmed for the GD... only the GE8 is proven.
The rear brakes on the other hand is a new ball game. |
^^^True, the fronts might be interchangeable.
I'm pretty sure the part #'s are somewhere on this site, I definitely recall some one doing it, probably a "fastbrake" thread, since that kit is similar to the T1R... iirc. |
Kuo's Garage, people that made the 5 lug kit, are working on a rear disc conversion. Its on the insight now which I was told shares a lot with the GD fit. I was told to keep an eye out… But I haven't seen or heard anything lately.
swade |
ok guys here are the pics, the rear disc seems like is the same as EG or DC disc, pads are the same for sure, the adapter plate with spindle probably can order from Honda
for the T1-R kit u can't get any parts anymore as Ben said they are discontinued http://img235.imagevenue.com/loc253/..._122_253lo.JPG http://img160.imagevenue.com/loc102/..._122_102lo.JPG http://img283.imagevenue.com/loc372/..._122_372lo.JPG http://img129.imagevenue.com/loc1080...122_1080lo.JPG http://img103.imagevenue.com/loc723/..._122_723lo.JPG http://img20.imagevenue.com/loc197/t..._122_197lo.JPG http://img247.imagevenue.com/loc120/..._122_120lo.JPG http://img256.imagevenue.com/loc171/..._122_171lo.JPG http://img272.imagevenue.com/loc474/..._122_474lo.JPG |
JUST as I thought, this just made my night. Thanks for posting up the pictures man and enjoy the rep!
