AirREX Air Ride Suspension now for Fit!
http://www.beangarage.com/catalog/forumbanner.png AirRex Air Suspension Product Listing on BeanGarage.com AirREX kits are here! Get low with these fully customizable air kits from AirREX! http://www.beangarage.com/catalog/im...suspension.jpg http://beangarage.com/catalog/images...engineered.jpg Vehicle Specific Upper Mount* Every AirREX upper mount is CNC machined from 6061 aluminum and then hard anodized. High density polyurethane bushings and/or high performance bearings completes the package to ensure exact fitment and durability. These upper mounts not only simplify installation but also improve ride quality, handling, and help provide maximum drop by replacing the bulky OEM upper mount. 12 Clicks Adjustable Damper A 12-way compression + rebound (together) adjustable damper is standard in every AirREX application. Each damper is matched to the air spring (bellow or sleeve) for the vehicle application and the user can further adjust for performance or comfort by the simple turn of a knob. Double Convoluted Bellow High durability 2-ply double convoluted air springs help provide both a comfortable ride at driving height and maximum drop when aired out. The size of the bellow is carefully chosen by AirREX engineers for each application to ensure correct spring rate and proper clearance for the vehicle. Twist Lock Compression Fitting Compression fittings are used to ensure a reliable leak free seal when used with 6mm or ¼ inch DOT nylon air tubing. Fully Threaded Damper Each AirREX damper is fully threaded to maximize adjustability similar to that of a coil over. Users can easily adjust for maximum drop or for maximum comfort at driving height by simply loosening the lower lock collar and turning the damper + air spring assembly up or down. Vehicle Specific Lower Mount Every AirREX application includes a vehicle specific lower bracket which is manufacture to exact OEM specification. Every tab or bracket for the hub, spindle, sway bar, brake lines, abs sensor, etc. is present to ensure proper fitment like that of the factory suspension. Some applications will include a high density polyurethane lower mount bushing. * Not all applications include upper mounts. Please check with us first for full details. http://www.beangarage.com/catalog/images/bellowinfo.jpg http://www.beangarage.com/catalog/images/sleeveinfo.jpg http://www.beangarage.com/catalog/images/multiinfo.jpg Kit comes with: Air strut front and rear (for cars that have 4 strut or coilover configurations) Air strut front and rear air bags (for cars that have strut or coilover front and shock and spring rears. For example, the xB’s and Cubes) Can be ordered in sleeve or bellow type air bags on the struts. We can also get the other products you will need for your kit, such as compressor, tank, water trap, air switches, pressure switch, and digital gauge readout. Let us know if you need any of these and we can prepare a quote for you! |
alright so what is the cost of the system itself
and what are the most important add ons such as compressor to make it a full kit prices through pm if possible thanks buddy |
PM'ing you right now.
Thanks! :hyper: |
hmmm how much would the whole kit cost with the compressor and important add ons
I want a price !!!!!!! Please pm me !!!!!!!
price for gd pleae
i'd like a price as well
interested to see how much it is for a full kit(bags, comp, pump) ge with digital readout
PM'ed you all, thanks!
Edit: :hyper: |
is this the same kit?
Honda Fit / Jazz EG by AirREX Digital air suspension - YouTube i remember asking this guy about the kit a long time ago. shipping was killer. how much shipped to hawaii 96804? |
Hows the ride quality? Bouncey?
Originally Posted by beangrower
(Post 1022173)
Honda Fit / Jazz EG by AirREX Digital air suspension - YouTube i remember asking this guy about the kit a long time ago. shipping was killer. how much shipped to hawaii 96804? Were you just looking to get the AirREX kit, or did you also need components? Thank you, Spencer Hows the ride quality? Bouncey? Nope, it feels like coilovers. Just stiff :) |
Originally Posted by ATLfit10
(Post 1022071)
PM me please!! Must know price! :)
PM'ed! Thank you!!:hyper:
how much for ge8?
PM'ed for total kit price. Thanks!
PM me for a price too for a GE8 kit. Thanks
PM'ed, thanks!
price for gd please.
